How to check if a specific endpoint has EFI password set using JamfPro?
  • June 23, 2020
  • 23 views
I am getting an error message "The operation couldn’t be completed. (com.jamfsoftware.task.errors error 5.)" on the logs of a policy for only one endpoint. All that the policy does is to remove the EFI password.
How do i fix that?
Is there a way to check through jump maybe that error is caused because the endpoint has no EFI password at all?
Best answer by karengarner
Did you find a fix for this? I am seeing the same issue
1 reply
  • February 27, 2024
