Rather than driving your clients to a specific branch URL manually, you can just update the rewrite rules for Apache. Search for the following <IfModule mod_rewrite.c> code block and add the last two lines.
/etc/apache2/sites-enabled/000-default
RewriteEngine On
RewriteCond %{HTTP_USER_AGENT} Darwin/9
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/content/catalogs/others/index-leopard.merged-1.sucatalog
RewriteCond %{HTTP_USER_AGENT} Darwin/10
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/content/catalogs/others/index-leopard-snowleopard.merged-1.sucatalog
RewriteCond %{HTTP_USER_AGENT} Darwin/11
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/content/catalogs/others/index-lion-snowleopard-leopard.merged-1.sucatalog
RewriteCond %{HTTP_USER_AGENT} Darwin/12
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
RewriteCond %{HTTP_USER_AGENT} Darwin/13
RewriteRule ^/index.sucatalog$ http://%{HTTP_HOST}/content/catalogs/others/index-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
</IfModule>
Edit: I believe you'll need to restart Apache after making these changes.
Sweet! Thanks Josh. I look forward to testing this out.
Hmm, I edited the 000-default file, added the new catalog entry and bounced the server but am not seeing it in /srv/SUS/html
@johnnasset
You have to make both modifications mentioned above. The first, to /var/lib/reposado/preferences.plist , tells Reposado to synchronize the updates for this new catalog. The second, to /etc/apache2/sites-enabled/000-default, tells any Mavericks client machine that requests the default "/index.sucatalog" file to instead grab the Mavericks specific "/content/catalogs/others/index-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog" without having to run the "defaults write" command mentioned in the first post.
Thanks Josh!! Worked like a charm.
@Josh_S, my 000-default has no <IfModule mod_rewrite.c>, etc.
Could you please post your complete file?
TIA
Alex
I made the changes to the preferences.plist on our NetSUS server as described in the original post, but even after restart, I'm not seeing any Mavericks or new updates (anything from Dec 2013) listed in either of our branches, even after syncing from the web interface. I'm fairly new to this appliance, so I'm not sure if I'm missing something simple. Any thoughts?
My updated plist file seems to mess up the web interface. I think it might be a problem with quotes getting messed up.
What is the best way to edit the plist file?
@MrDros - Look at the very bottom of the file, it should be immediately prior to the "</VirtualHost>" tag. If your Apache config file doesn't have a mod_rewrite section, you may have to actually enable the rewrite module or something else went wrong during the NetSUS installation. I can't immediately recall, but I think an early version of the NetSUS appliance didn't use mod_rewrite. If that's the case, I'd try a new install/upgrade to v2.
@mwilkerson - I can only think that there is a typo in your file, or it is being blocked (proxy?). I would try copy/pasting the URI (everything between the <string> tags) into a web browser. You should either display or download the sucatalog file.
@garyj - Opinions vary on this. If you want to edit it via a GUI application, you could transfer it to your mac and edit it with a plain text application (such as TextWrangler) and then transfer it back. If you want to edit it in place, you could either use "vi" or "nano". If you decide to edit it in place, make sure you make a backup of the original in case something gets messed up. It's possible that "smart quotes" are messing up the formatting. Looking at the original post, a few of those quotes used do look like some program may have accidentally made them "smart".
The only change you should be making to the reposado config file is to add in the "<key>AppleCatalogURLs</key>" and the next lines from "<array>" to "</array>"
Thanks, nano did the trick.
I've been having some of the same issues above, but have gotten the Netsus to see and download the 10.9 updates. I changed the reposado/preferences.plist and the 000-default files as above. My issue now is that my clients are not checking in to get the updates. Here is the URL my clients are using to check Netsus. I have 2 branches, QA and CORP. Right now I'm only using the QA branch for testing. Is the below the correct?
Before enabling 10.9 updates:
http://netsus/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard.merged-1_QA.sucatalog
After enabling 10.9 updates:
http://netsus/content/catalogs/others/index-10.9-mountainlion-lion-snowleopard-leopard.merged-1_QA.sucatalog
NetSUS 3.0 is already out w/ 10.9 updates.
Can anybody please refresh my memory on how to update an existing NetSUS from 2.0 to 3.0 via the command line?
wget http://jamfsoftware-content.s3.amazonaws.com/downloads/NetSUS_3.0.run
and
sudo sh NetSUS_3.0.run
Can't take credit for above. ClifHirtle posted the commands under the NetSUS 2.0 topic.
Hit a new speed bump. I rebuilt my NETSUS server with 3.0 and it's successfully downloading 10.9.1 updates.
My issue now is: my mavericks test machine running 10.9 is not getting the 10.9.1 update. I can get other non-OS updates fine. My configuration profile scoped to the machine is setting the URL to http://netsus/content/catalogs/others/index-10.9-mountainlion-lion-snowleopard-leopard.merged-1_QA.sucatalog
Any suggestions?
@mtyles
Pardon the obvious question but do you have all of the 10.9.1 updates checked as enabled in the Netsus? There are separate updates for the rMBP and MacPro.
Here are the 10.9 updates I see and have all of them checked:
Name Version Date
Compatibility Update for 10.9 Package Details 1.0 2013-12-18
OS X Mavericks GM Seed Package Details 10.9 2013-10-07
OS X Update Package Details 10.9.1 2013-12-16
OS X Update Package Details 10.9.1 2013-12-19
All of a sudden, it started working this morning. I'm now getting the 10.9.1 updates.
@Josh_S
I made both modifications mentioned above.
1. to /var/lib/reposado/preferences.plist , tells Reposado to synchronize the updates for this new catalog.
>>>>This works for me.
- to /etc/apache2/sites-enabled/000-default, tells any Mavericks client machine that requests the default "/index.sucatalog" file to instead grab the Mavericks specific "/content/catalogs/others/index-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog" without having to run the "defaults write" command mentioned in the first post.
>>>>This dos not work for me.
I'm not sure if I did something wrong or missing something. Any thoughts?
this is what my 000-default looks like:
<VirtualHost *:80>
ServerAdmin webmaster@localhost
DocumentRoot /srv/SUS/html/
<Directory />
Options FollowSymLinks
AllowOverride All
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access.log combined
Alias /doc/ "/usr/share/doc/"
<Directory "/usr/share/doc/">
Options Indexes MultiViews FollowSymLinks
AllowOverride None
Order deny,allow
Deny from all
Allow from 127.0.0.0/255.0.0.0 ::1/128
</Directory>
Alias /NetBoot/ "/srv/NetBoot/"
<Directory /srv/NetBoot/>
AllowOverride None
Order allow,deny
allow from all
</Directory>
RewriteEngine On
RewriteRule ^index.sucatalog$ http://%{HTTP_HOST}/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
</IfModule>
</VirtualHost>
@shakim
I don't have an Ubuntu test server right now, but it *looks* right. Did you remember to restart the Apache HTTPD service after making modifications? I believe, for Ubuntu, the command is the following. Or you could just restart the whole server. It's overkill, but it works.
sudo service apache2 restart
To troubleshoot, you can turn on the develop menu within Safari, other browsers have similar functionality as well, to manually modify your user agent to be "Darwin/13" and then try connecting to your server and grabbing the /index.sucatalog file to see if it correctly redirects you.
However, v3.0 of the NetSUS appliance is out now and enables 10.9 updates out of the box. Might just look at upgrading, it would probably be easier than troubleshooting.
https://jamfnation.jamfsoftware.com/discussion.html?id=9483
I'm having to manually change my Catalog URL from
http://10.86.6.124/content/catalogs/index_Cabot.sucatalog
to
http://10.86.6.124/content/catalogs/others/index-10.9-mountainlion-lion-
to get my clients to see the 10.9 updates, is there any reason for this or a fix i can change on the NETSUS appliance to get this working?
@Josh_S
great help! thanx a lot
@jthurwood
We still need to make this Catalog URL change that was originally detailed by the Reposado documentation. I'm not aware of anything we can change on the NetSUS to accommodate this. Does anyone know otherwise? Right now we just have a policy that changes the Catalog URL for our clients, but the NetSUS web interface shows the default, and currently incorrect, Catalog URL.
@jthurwood
reposado shows
URL: http://sus.mycompany.corp/content/catalogs/index_BRANCHName.sucatalog
but you use for OS X v10.8
http://sus.mycompany.corp/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard. merged-1_BRANCHName.sucatalog
so you deploy
defaults write /Library/Preferences/com.apple.SoftwareUpdate CatalogURL http://sus.mycompany.corp/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard. merged-1_BRANCHName.sucatalog
My whole scenario - Everyone prefers different ways - I just list what I did , hoping it helps.
I had to decide between
A) Use the Casper payload "Configure Software Updates"
uses: defaults read /private/var/root/Library/Preferences/com.apple.SoftwareUpdate CatalogURL
set by e.g. Casper Network segments
B) Use Files and Processes / Execute command: "softwareupdate -iva"
uses: defaults read /Library/Preferences/com.apple.SoftwareUpdate CatalogURL
I chose method B)
0) I upgraded NetSUS to 3.0
1) Under Network segments I have no Softwareupdate Server
2) I do not use the Casper payload Software Updates
3) I use a policy with ?defaults write /Library/Preferences/com.apple.SoftwareUpdate CatalogURL <Branch URL>
with the URL for each OSX:
OS X v10.8
http://sus.mycompany.corp/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard. merged-1_<Branch name>.sucatalog
4) I use a policy with Execute command: "softwareupdate -iva"
This works for me since I do not want the machines to get Updates "abroad"
You have to choose different way when you want the machines to reach the normal "Apple SUS" without any changes for the user. Josh_S pointed that out - in his solution the Apache redirects the "normal" request for Updates without changing the Catalog URL on the client when the machines are in the right network.
Hi @Josh_S I have modified the preferences.plist file in the attempt to only bring down 10.7-10.9 updates. However, when I run a sync from the web console it is still pulling updates back to 2005.
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>CurlPath</key>
<string>/usr/bin/curl</string>
<key>LocalCatalogURLBase</key>
<string></string>
<key>UpdatesMetadataDir</key>
<string>/srv/SUS/metadata/</string>
<key>UpdatesRootDir</key>
<string>/srv/SUS/html/</string>
<array>
<string>http://swscan.apple.com/content/catalogs/others/index-lion-snowleopard-leopard.merged-1.sucatalog</string>
<string>http://swscan.apple.com/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog</string>
<string>http://swscan.apple.com/content/catalogs/others/index-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog</string>
</array>
</dict>
</plist>
I have tried including the top level index catalog as well with the same results. I also backed up and deleted the /srv/SUS/metadata/ProductInfo.plist then ran a sync again in the hopes that would clear that list out and download just what had been specified in /var/lib/reposado/preferences.plist. I am still getting stuff back to 2005.
Can you think of anything I am missing? BTW I have not selected the checkbox to actually download the updates themselves, just catalogs. I figure I can get things working correctly before I fill up the drive with non needed updates. Is it as simple as editing the catalog file names to remove reference to leopard and snow leopard? Somehow I think not.
Thanks
