How to make Symantec Uninstallation completely silent?
  • December 20, 2021
  • 8 replies
  • 173 views
Hey everyone - I'm very much a newbie here but would love some advice - at the moment I am uninstalling Symantec from all our macs and installing Windows Defender. I'm using the command script from here to uninstall Symantec -
https://knowledge.broadcom.com/external/article?legacyId=TECH103489
My policy places the command file at a local location on each mac and then runs it from there, however on my test mac I've found I'm still being prompted if I want to uninstall Symantec and  1 or 2 other prompts that I have to click on before it runs...is there anyway to make it fully silent without any interaction from a user?
Best answer by hallfire
Hi.
Im my case I modify the script for not be prompt. I force the choice on the script for uninstall , and I force the yes entry directly on the script.
Before execute the script you need to remove Symantec Endpoint Protection.app with a rm command (if your on macOS 10.15 like us)
  • December 21, 2021
Hi.
  • December 21, 2021
Hi.
Would you mind sharing your script with me? I'm a beginner with coding and usually just copy paste scripts to run.
  • December 22, 2021
https://www71.zippyshare.com/v/QU2miJ4U/file.html
You can create a package with composer
Place the file RemoveSymantecMacFiles.command in /Private/tmp
In preinstall script use the this command :
rm -R "/Applications/Symantec Solutions/Symantec Endpoint Protection.app"
In post install script use this command :
/tmp/RemoveSymantecMacFiles.command -A
rm /tmp/RemoveSymantecMacFiles.command
Hello,
From shared link can't download the files. Tt is downloading some malware and doing nothing. Try the below link to share the files.
https://wetransfer.com
Thank you
  • December 22, 2021
https://we.tl/t-FQxYOUyvvM
here is the command file on weetransfert
Thanks for uploading the customised Symantec removal tool. But I am getting this one pop up. Is this can be suppressed as well?
mhasman
Forum|alt.badge.img+22
  • December 27, 2021
Is there any way to remove SEP system extensions by running the script/commands?
Is there anyway to get this script from someone on this thread please? @hallfire @JAMFNoob @user-cflvsqhVEZ
