How to use Casper Variables in expect Script
  • August 25, 2015
  • 8 views
L3nny5
Hello,
I have an expect script which I copied from user "ktappe" and I want to integrate the $4-$11 variables so I don't have to change the script every time I need to change the password.
This example doesn't work. :-(
#!/usr/bin/expect -f
set newpassword $5
set oldpassword $6
spawn firmwarepasswd -setpasswd
expect {
    "Enter password:" {
        send "$oldpassword
        exp_continue
    "Enter new password:" {
        send "$newpassword
        exp_continue
    "Re-enter new password:" {
        send "$newpassword
        exp_continue
davidacland
  • August 25, 2015
Try [lindex $argv 5] and [lindex $argv 6]
set new password [lindex $argv 5]
set oldpassword [lindex $argv 6]
expect {
    "Enter password:" {
        send "$oldpassword
        exp_continue
        send "$newpassword
        exp_continue
        send "$newpassword
        exp_continue
davidacland
  • August 27, 2015
Did that work in the end?
L3nny5
  • August 28, 2015
Sorry. Haven't had the time yet to test it until now.
Unfortunately it does not work. But i figured it out myself!
The number of the variable you are using needs to be minus 1. So if you are using variable 4 and 5, you have to use [lindex $argv 3] and [lindex $argv 4]
The Script for variable 4 and 5 looks like this and is working:
set newpassword [lindex $argv 3]
set oldpassword [lindex $argv 4]
expect {
    "Enter password:" {
        send "$oldpassword
        exp_continue
        send "$newpassword
        exp_continue
        send "$newpassword
        exp_continue
