How to use Patch management for Jamf Protect?
  • January 5, 2021
  • 24 views
I'd like to start using Patch management with our new Jamf Protect subscription. It looks like there is a problem with the Extension attributes section. Can someone help me with this? I'm not sure what to do.
  • January 5, 2021
Hi. You just have to Accept the Extension Attribute. This only happens with Jamf provided EAs for Patch Management. Click on the Extension Attribute tab just as you have in your image and click the Edit button. A new "Accept" button should show up under the "Jamf Protect" title. Click that button and hit Save and you should be all set.
  • January 5, 2021
Lol. Thanks. I got it now.
