Anyone can help me I can not connect to Wi-Fi 802.1x using AD Certificate Authentication.
Here is configuration file:
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN"
"http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>PayloadContent</key>
<array>
<dict>
<key>PayloadCertificateFileName</key>
<string>ca0101.sabay.office_Sabay Subordinate CA 1</string>
<data>MIIFKDCCAxCgAwIBAgITGAAAAAVt2M2Tbx6nrQAAAAAABTANBgkqhkiG9w0BAQ0F
ADBCMQswCQYDVQQGEwJLSDEbMBkGA1UEChMSU2FiYXkgRGlnaXRhbCBDb3JwMRYw
</data>
<key>PayloadDescription</key>
<string>Sabay Subordinate CA 1 Certificate</string>
<key>PayloadDisplayName</key>
<string>Sabay Subordinate CA 1</string>
<key>PayloadIdentifier</key>
<string>com.sabay.cacertificate.ca0101</string>
<key>PayloadType</key>
<string>com.apple.security.root</string>
<key>PayloadUUID</key>
<string>9768C058-9437-4F51-B7E6-AEAEF9717531</string>
<key>PayloadVersion</key>
<integer>1</integer>
</dict>
<dict>
<string>ca01.sabay.office_Sabay Root CA</string>
<data>MIIFXzCCA0egAwIBAgIQPiI44o7JSJFNMEoBDNEOxDANBgkqhkiG9w0BAQ0FADBC
MQswCQYDVQQGEwJLSDEbMBkGA1UEChMSU2FiYXkgRGlnaXRhbCBDb3JwMRYwFAYD
VQQDEw1TYWJheSBSb290IENBMB4XDTE2MDgxNzA3MDczMFoXDTM2MDgxNzA3MTcy
</data>
<string>Sabay Root CA Certificate</string>
<string>Sabay Root CA</string>
<string>com.sabay.cacertificate.ca01</string>
<string>65295CEA-70C9-431A-86D1-F5581F2FED4F</string>
</dict>
<dict>
<string>ca0102.sabay.office_Sabay Subordinate CA 2</string>
<data>MIIGQzCCBCugAwIBAgITGAAAAATMtBiO2u3hygAAAAAABDANBgkqhkiG9w0BAQ0F
FAYDVQQDEw1TYWJheSBSb290IENBMB4XDTE2MDgyNDE1MDExOVoXDTI2MDgyNDE1
</data>
<string>Sabay Subordinate CA 2 Certificate</string>
<string>Sabay Subordinate CA 2</string>
<string>com.sabay.cacertificate.ca0102</string>
<string>CE70721D-DBC5-44B5-92AA-CAEEE78BA944</string>
</dict>
<dict>
<key>EAPClientConfiguration</key>
<dict>
<key>AcceptEAPTypes</key>
<array>
<integer>13</integer>
</array>
<key>PayloadCertificateAnchorUUID</key>
<array>
</array>
</dict>
<key>EncryptionType</key>
<string>WPA</string>
<key>HIDDEN_NETWORK</key>
<true/>
<key>Interface</key>
<string>BuiltInWireless</string>
<key>PayloadCertificateUUID</key>
<string>0EF3981E-0DD8-4A62-A792-A859E734DCB6</string>
<string>EAP-TLS 802.1x configuration</string>
<string>Sabay Office</string>
<string>com.apple.eaptls.8021x.wifi</string>
<key>PayloadOrganization</key>
<string>Sabay Digital Corp</string>
<string>com.apple.wifi.managed</string>
<string>9574A054-8A51-46B3-8766-D8542DB0D843</string>
<key>SSID_STR</key>
<string>Wi-Fi</string>
<key>SetupModes</key>
<array>
<string>System</string>
</array>
</dict>
<dict>
<key>CertServer</key>
<string>http://request_Certificate_URL/certsrv</string>
<key>CertTemplate</key>
<string>Sabay-WorkstationAuthentication</string>
<key>UserName</key>
<string></string>
<key>Password</key>
<string></string>
<key>PromptForCredentials</key>
<false/>
<key>ADCertServerCertificateIDReplySearchString</key>
<string>YOUR_CERT_ID_REPLY_SEARCH_STRING_HERE_OPTIONAL</string>
<string>Computer Certificate</string>
<string>com.apple.ADCertificate.managed</string>
<string>D275DE5A-5BD7-4594-B16D-F697BC58ED28</string>
<key>deleted</key>
<false/>
</dict>
</array>
<string>com.sabay.ADCertificate.managed</string>
<key>PayloadRemovalDisallowed</key>
<true/>
<string>SystemConfiguration</string>
<string>78BB1EE4-EC9E-463A-86D7-00DA73F26733</string>
</dict>
</plist>
And after install this .mobileconfig and tried to connected Wi-Fi is was need Username:
