I need help with a script using "if" an "then"
  • September 24, 2021
  • 5 replies
  • 148 views
howie_isaacks
I need to look for four folders that should have been automatically added to each user's Documents folder. I wrote a simple script that should check if the folders exist. If they don't, it will run the Jamf policy that creates them. The problem I keep running into is that when I test the script, the results tell me that the folders exist even when they don't. Obviously I'm doing something wrong but I can't figure out what. Please help! The script is below. If I manually type a command the commands in Terminal, I can get an accurate response. The script tells me that the folders are present whether they are or not. What the heck am I doing wrong?
#!/bin/sh ###Looks for PDF folders in a user's Documents folder. If the folders are not present this script will run the Jamf policy that creates them. currentuser=`/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'` echo $currentuser pdfFolders=$( /Users/$currentuser/Documents/"PDFs for Client Reports" /Users/$currentuser/Documents/"PDFs for ATBs" /Users/$currentuser/Documents/"PDFs for Estimates" /Users/$currentuser/Documents/"PDFs for Insertion Orders" ) if [ -d $pdfFolders ] then echo "Folders present" else echo "Folders not present"; jamf policy -event install-fmfolders fi
Best answer by dwbergstrom
I think you might need to iterate over the values in the array of directories.  Something like:
for i in "${pdfFolders[@]}" do if [ -d $i ] then echo "Folder $i present" else echo "Not all folders are present...running policy to add" jamf policy -event install-fmfolders break fi done
Pretty sure the "$" needs to be left out when declaring the array as well:
pdfFolders=(...)
dwbergstrom
pdfFolders=(...)
howie_isaacks
pdfFolders=(...)
Interesting. I'm confused now since I have other scripts that use $ after =. They work but this one won't. I will give this a try.
howie_isaacks
pdfFolders=(...)
This works! THANK YOU!!!
Of course now I have the mystery of why other scripts work that use $ after = but I will deal with that later 😊
@howie_isaacks You're probably getting confused with the difference between an array and a variable. A variable can either just be a string, such as:
somename="hello"
So when somename is called later it equals hello.
Or you can set a variable with the output of a command, such as:
somename=$(somecommand)
And somename then becomes the results of somecommand
With an array it just needs parens to enclose the contents. The $ is not valid for declaring a shell array.
somearray=(one two three)
With the above, when iterating over it, it will print out
one
two
three
Hope that helps clarify it a bit.
howie_isaacks
somename="hello"
one
two
three
Thanks! I remember that.... now 😎 I appreciate all the help!
