Ideas on Passing a Key to an after installation for Jumpcloud
  • November 18, 2021
  • 0 replies
  • 28 views
I'm currently trying to find the best way to install the Jumpcloud package to a machine and then also pass a connect key via script. The connect key will not change more than a few times a year at which part I can update the script.
I'm trying to "dumb down" the below script which also installs the Jumpcloud agent using a specific user and then silently passes the connect key. I no longer need the specific user and just need the package installed and then the key passed silently under the logged in user.  The current script also pulls the current version of the Jumpcloud agent to install.
I'm either trying to figure out way to modify this script to just download and install the Jumpcloud agent using the Amazon link in the script and then silently pass the connect key or if it's easier and less problematic attach a shorter script that just passes the connect key during the PKG install via a policy ie: the Jumpcloud.pkg is attached to a policy that also triggers a script to pass the Connect Key.
Due to other internal complications the script itself will not work for my use case.
If anyone has any ideas they would be very much appreciated.
# Populate the below variables before running the command
# Enter your connect key within the '' of YOUR_CONNECT_KEY='' with your orgs key found on the new system aside in the admin console
YOUR_CONNECT_KEY='XXXXXX'
# Enter the SECURETOKEN_ADMIN_USERNAME within the '' of SECURETOKEN_ADMIN_USERNAME=''
SECURETOKEN_ADMIN_USERNAME=USERREMOVED’
# Enter the SECURETOKEN_ADMIN_PASSWORD within the '' of SECURETOKEN_ADMIN_PASSWORD='' with the credentials of the admin with a secure token
SECURETOKEN_ADMIN_PASSWORD='XXXXX'
# Flag for installing without checking SECURETOKEN_ADMIN_USERNAME or SECURETOKEN_ADMIN_PASSWORD
SILENT_INSTALL=1
# You can also specify one or more values with parameters
# -k YOUR_CONNECT_KEY -u SECURETOKEN_ADMIN_USERNAME -p SECURETOKEN_ADMIN_PASSWORD
while getopts k:u:p:sh option; do
case "${option}" in
k) YOUR_CONNECT_KEY=${OPTARG} ;;
u) SECURETOKEN_ADMIN_USERNAME=${OPTARG} ;;
p) SECURETOKEN_ADMIN_PASSWORD=${OPTARG} ;;
h)
printf "Options:
-k Your JumpCloud Connect Key
-u System Admin Username
-p System Admin Password\\n\\n"
s) SILENT_INSTALL=1 ;;
*) echo "Invalid parameter"
exit 1
esac
done
#--------------------Do not modify below this line--------------------
MacOSMajorVersion=$(sw_vers -productVersion | cut -d '.' -f 1)
MacOSMinorVersion=$(sw_vers -productVersion | cut -d '.' -f 2)
MacOSPatchVersion=$(sw_vers -productVersion | cut -d '.' -f 3)
if [[ $MacOSMajorVersion -eq 10 && $MacOSMinorVersion -lt 13 ]]; then
echo "Error: Target system is not on macOS 10.13"
exit 2
# This function checks whether the given user is secure token enabled:
secureTokenEnabledForUser() {
# secure token is not supported on versions < 10.13
if [[ "$MacOSMajorVersion" -eq 10 && "$MacOSMinorVersion" -lt 13 ]]; then
return 1
# on earlier versions of High Sierra, we should use dscl:
if [[ "$MacOSMajorVersion" -eq 10 && "$MacOSMinorVersion" -eq 13 && "$MacOSPatchVersion" -lt 4 ]]; then
if [[ $(dscl . read /Users/"$1" AuthenticationAuthority | grep ";SecureToken;" -c) -gt 0 ]]; then
return 0 # success
else # on 10.13.4 or higher we can just use sysadminctl to get the secureToken status without admin credentials:
if [[ $(sysadminctl -secureTokenStatus "$1" 2>&1) == *"Secure token is ENABLED for user"* ]]; then
return 0 # success
return 1 # SecureToken is NOT enabled
isAdminUser() {
if [ "$(id -Gn "$1" | grep -c -w admin)" -gt 0 ]; then
return 0 # user is an admin
return 1
checkAndReadInUsername() {
printf "\\nSecure Token enabled admin required\\n"
printf "Checking %s for Secure Token admin access\\n" "${SECURETOKEN_ADMIN_USERNAME}"
sleep 1
if (secureTokenEnabledForUser "${SECURETOKEN_ADMIN_USERNAME}") && (isAdminUser "${SECURETOKEN_ADMIN_USERNAME}"); then
echo "** ($SECURETOKEN_ADMIN_USERNAME) is verified as a Secure Token admin **"
return 0
echo "--------"
while ! (secureTokenEnabledForUser "${SECURETOKEN_ADMIN_USERNAME}") || ! (isAdminUser "${SECURETOKEN_ADMIN_USERNAME}"); do
printf "\\nThe username: %s is not a Secure Token enabled admin.\\nTo enable the JumpCloud Agent to manage FileVault users, \\nplease provide the username of a Secure Token enabled \\nadmin user on this system.\\n" "${SECURETOKEN_ADMIN_USERNAME}"
echo "--------"
read -rp 'Secure Token Admin Username: ' SECURETOKEN_ADMIN_USERNAME
done
echo "** (${SECURETOKEN_ADMIN_USERNAME}) is verified as a Secure Token admin **"
return 1
verifyPasswordForUser() {
printf '\\nVerifying Password\\n'
VERIFYPASSWORD=$(dscl /Local/Default -authonly "${SECURETOKEN_ADMIN_USERNAME}" "${SECURETOKEN_ADMIN_PASSWORD}")
if [ -z "$VERIFYPASSWORD" ]; then
return 0
return 1
readInPasswordForUser() {
while true; do
if [ -n "$SECURETOKEN_ADMIN_PASSWORD" ]; then
if ! verifyPasswordForUser; then
printf "\\nERROR: Incorrect Password for user %s !\\n" "${SECURETOKEN_ADMIN_USERNAME}"
printf "\\nPassword verified for user %s \\n" "${SECURETOKEN_ADMIN_USERNAME}"
break
echo 'Password cannot be blank'
read -rsp "Please enter the password for ${SECURETOKEN_ADMIN_USERNAME}:" SECURETOKEN_ADMIN_PASSWORD
echo ''
done
# Install Rosetta2 on M1 (Apple Silicon) Macs if not already installed
installRosettaForM1() {
BIG_SUR_MAJOR=11
# Save current IFS (Input Field Separator) state
OLDIFS=${IFS}
# retrieve OS version info
IFS='.' read -r osvers_major osvers_minor osvers_dot_version <<<"$(/usr/bin/sw_vers -productVersion)"
# restore IFS to previous state
IFS=${OLDIFS}
if [[ ${osvers_major} -ge ${BIG_SUR_MAJOR} ]]; then
# Check processor to see if we even need Rosetta2
processor=$(/usr/sbin/sysctl -n machdep.cpu.brand_string | grep -o "Intel")
if [[ -n "${processor}" ]]; then
echo "Intel processor installed; no need to install Rosetta2"
# Check for an installer receipt for Rosetta. If no receipt is found,
# perform a non-interactive install of Rosetta.
rosetta_check=$(/usr/sbin/pkgutil --pkgs | grep "com.apple.pkg.RosettaUpdateAuto")
if [[ -z "${rosetta_check}" ]]; then
if ! /usr/sbin/softwareupdate --install-rosetta --agree-to-license; then
echo "Rosetta installation failed!"
echo "Rosetta has been successfully installed."
echo "Rosetta is already installed. Nothing to do."
echo "System is running macOS ${osvers_major}.${osvers_minor}.${osvers_dot_version}."
echo "No need to install Rosetta on this version of macOS."
# require connect key
if [ -z "$YOUR_CONNECT_KEY" ]; then
echo 'Connect key is required. Please provide one in the script or via the -k parameter'
exit 1
# check connect key length
if [ ${#YOUR_CONNECT_KEY} != 40 ]; then
echo 'Connect key is not 40 characters. Please provide a valid connect key in the script or via the -k parameter'
exit 1
if [ "$SILENT_INSTALL" -eq "0" ]; then
if [ -z "${SECURETOKEN_ADMIN_USERNAME}" ]; then
# if empty, set SECURETOKEN_ADMIN_USERNAME to the user running the script
SECURETOKEN_ADMIN_USERNAME=$(stat -f '%Su' "${HOME}")
# check to make sure the user is a secure token enabled admin
# Install Rosetta2 for M1 (Apple Silicon) Macs
installRosettaForM1
curl --silent --output /tmp/jumpcloud-agent.pkg "https://s3.amazonaws.com/jumpcloud-windows-agent/production/jumpcloud-agent.pkg" >/dev/null
mkdir -p /opt/jc
cat <<-EOF >/opt/jc/agentBootstrap.json
"publicKickstartUrl": "https://kickstart.jumpcloud.com:443",
"privateKickstartUrl": "https://private-kickstart.jumpcloud.com:443",
"connectKey": "$YOUR_CONNECT_KEY"
EOF
cat <<-EOF >/var/run/JumpCloud-SecureToken-Creds.txt
$SECURETOKEN_ADMIN_USERNAME;$SECURETOKEN_ADMIN_PASSWORD
EOF
=skip
EOF
# The file JumpCloud-SecureToken-Creds.txt IS DELETED during the agent install process
installer -pkg /tmp/jumpcloud-agent.pkg -target /
result=$(echo "$?")
if [[ $result -eq "0" ]];then
echo "JumpCloud Agent Installed Successfully"
echo "JumpCloud Agent Install Failed"
exit 1
