Renaming the subject...
On 8/18/10 8:09 AM, "Timothy Morris" <t.morris at qut.edu.au> wrote:
Ideally, you'd use something like:
defaults read /Library/ScriptingAdditions/Adobe Unit
Types.osax/Contents/Info CFBundleVersion
However, I just downloaded what I assume to be the latest version of the
osax from <http://kb2.adobe.com/cps/516/cpsid_51615.html> and while the
website says "2.1.0", I see the CFBundleVersion is still listed at "2.0.0".
Not sure you can get anything useful from the osax file itself if it's not
correct to begin with.
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
This has just popped up for us.. I needed to change the CFBundleVersion of the correct Adobe Units Type & create a smart group to scope policy..
Anyways.. all steps can be found on my blog here: http://macmule.com/2011/03/09/installing-adobe-unit-types-2-1-0/
Regards,
Ben Toms
IT Support Analyst GREY Group
The Johnson Building, 77 Hatton Garden, London, EC1N 8JS
T: +44 (0) 20-3037-3819 |  Main: +44 (0) 20 3037 3000 | IT Helpdesk: +44 (0) 20 3037 3883
