iLife 11 with Lion
  • July 3, 2012
  • 5 replies
  • 39 views
Forum|alt.badge.img+20
HI Folks,
I have read through most, if not all, of the posts related to packaging up iLife 11. I used Jared's new manifest and I have had no luck. Essentially, we are missing a couple of the apps, library files and a few more pieces. the question I pose is whether or not, anyone has successfully packaged ALL of the Apple components for iLife 11 so it is deployable and works.
The existing methods put apps into a folder called ROOT/Applications and other strange places. If you know of a tried and true method, I would be forever welcome to a solution.
Mick
  • July 3, 2012
the root issue is an issue with Composer 8.52
I suggest asking your JAMF rep for Composer 8.51.
Otherwise, if you quit composer and reopen before building the DMG it should take care of the ROOT issue. I found it easier to just work with 8.51 than trying to remember to quit/reopen.
stevewood
Forum|alt.badge.img+38
  • July 3, 2012
I use the method Craig described in this post:
https://jamfnation.jamfsoftware.com/discussion.html?id=2256
Haven't had a problem yet. Now, I did have to go through and re-create the DMG of the original install disk after Apple's "Patch Apocalypse", but I used Greg Neagle's script and instructions for fixing it:
http://managingosx.wordpress.com/2012/03/24/fixing-packages-with-expired-signatures/
But once i fixed the packages, I followed Craig's post to create an iLife deployment method that works.
donmontalvo
Forum|alt.badge.img+36
  • July 4, 2012
I found this technique that was posted a while back to be very easy, and takes about as long to complete as it does to eat a slice or pizza and a bottled water. OK, two slices...who's counting?
https://github.com/MagerValp/iLife-repackaging
This is of course for packaging from DVD media...now Apple is going all App Store on us, follow Apple's standard deployment process...simple overview here:
http://www.apple.com/mac/volume-licensing/
Don
  • July 5, 2012
Thank you all for your responses. Going back to 8.51 I was able to package up for Lion just fine. Thanks for your guidance!
Mick
  • July 24, 2012
Thanks for the advice, I can confirm 8.51 works with the iLife '11 revised manifest.
Carrie
