At JAMF Support's request, I am posting this question here.
Has anyone attempted imaging one of the new Mac Mini aluminum machines
using Casper 7.31?
The 10.6.3 rev of the Mac Mini aluminum (10D2235) is newer than the 10.6.3
combo update from Apple (10D578) and therefore I added a .dmg of the Mac
Mini's installer DVD to Casper Admin.
1) Using the DVD .dmg itself as part of the Mac Mini's package
configuration, the OS install is passed over in a few seconds without
attempting to install and imaging continues with the next package.
2) If I create a Custom OS Install based on the DVD from the Mac Mini and
add that to my configuration I receive:
An exception of class NilObjectException was not handled. The
application must shut down.
3) If I attempt to image the machine using my Retail 10.6.3 DVD .dmg and
then update with 10.6.4, I receive this in the log file:
Error: The OS Installer failed because of an XML parsing error it the
installer application. It was installed, but packages with underscores in
the name have been deployed incorrectly.
Has anyone been able to image a Mac Mini using Casper Imaging 7.31 and any
Mac OS X Install DVD .dmg file?
My next attempt will be to create a Mac OS X 10.6.4 .dmg and try using
that.
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
