Does anyone have a script or some way of importing Serial Numbers of iPads into a Pre-Stage Enrollment, while removing the Serial Number from whatever Pre-Stage Enrollment the device is currently in)?
OR
Import a list of Serial Numbers to remove iPads from any Pre-Stage Enrollment
another script to
Import a list of Serial Numbers to add iPads to a Pre-Stage Enrollment
Thank you
Be the first to reply!
