In-Place macOS Sierra Upgrade Script
Show first post
  • December 11, 2018
Thank you @Rosko for the effort and support you are putting into your script.
I am in the process of trying to deploy High Sierra via Self Service and was stuck for the longest time putting in the user variables.
It turns out, every time I tried to put in /Applications/Install macOS High Sierra.app in variable $4, the JSS would give an error and tell me to check the logs. Checking the logs, I find:
QueryException: Data too long for column 'parameter_1' at row 1
I presume this is MySQL barking at me.
Sure enough, if I put in a shorter path it works.
I am now trying it with the string hard-coded into the script.
Anybody else have issues with the user variables?
