I just did my first instaDMG Base image and compiled it with no issues. But my question is how do you set the setting like:
Turning off Mac Updates
Setting the Sleep mode time
And others
Or is this done afterwards? Meaning do you image a machine via Casper using the new instaDMG base image then make the setting changes the build another base image from Composer? t doesn't seem right.
Thanks
