Installing Cisco AMP
  • March 28, 2022
  • 72 views
Hello All,
Any info on how to get Cisco AMP to install on machines. I have the DMG downloaded which has a pkg inside. I followed the instructions at this Jamf community URL:https://community.jamf.com/t5/jamf-pro/deploying-cisco-amp-v-1-9/td-p/213222
I tried just using the dmg as well with no luck, any hints or tips are really appreciated
Best answer by ajamfadmin1810
needed to add -i to grep command
  • March 28, 2022
I have tried using the script in the URL above and im getting the following error. I have confirmed I can reach the URL from a browser by just using the URL bar. I have replaced our actual full URL with the word Redacted for the post
Script result: + ciscoAMPPath='/Applications/Cisco AMP/AMP for Endpoints Connector.app/Contents/Info.plist' + redirectingURL='https://console.amp.cisco.com/install_packages/REDACTED/download?product=MacProduct' + localInstallerVolume=/Volumes/ampmac_connector + localInstallerPackage=ciscoampmac_connector.pkg + tmpFolder=/Library/CiscoAMPtmp + checkAndGetURLs ++ curl --head 'https://console.amp.cisco.com/install_packages/REDACTED/download?product=MacProduct' ++ grep Location: ++ awk '{print $2}' % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 + dmgURL= + [[ -z '' ]] + echo 'Unable to retrieve DMG url. Exiting...' Unable to retrieve DMG url. Exiting... + exit 1
  • March 28, 2022
Person
  • March 29, 2022
Yes this jamf article brought up this same issue.  https://community.jamf.com/t5/jamf-pro/error-when-deploying-amp-for-endpoints-policy/m-p/247353
