Installing MathType
  • September 24, 2013
  • 5 replies
  • 21 views
Hi, has anyone tried packaging and deploying MathType? I can get it installed but the license key doesnt come down with it and I cant figure out where that is stored.
Thanks
Mark
  • November 13, 2013
Hi Mark,
Did you ever get this package built? I'm having the same issue now!
Thanks
Laura
  • November 13, 2013
Hi Laura,
I found out the license information is kept at Mac HD/Users/Home Folder/Library/Preferences/com.DesignScience.DSMT6.plist. However I tried capturing a snapshot before & after installing and activating it, but it wouldnt carry the licensing info to the client install even with FEU FUT checked off. I think its a flaw with their software because the licensing doesnt get carried over to all users even on the same machine. Each user would have to activate it. Since I only had 18 people using it, I created the package and gave them the license key to use once it was installed.
Thanks
Mark
  • November 25, 2013
Hi Mark,
I managed to get this packaged, an it seems to be working. If you create a DMG and make sure the user preferences are included in the package, the following files are where the licensing info is stored:
Home folder/Library/Preferences/
com.DesignScience.DSMT6.plist.lockfile
com.dessci.CrashReportTool.plist
com.dessci.CrashReportTool.plist.lockfile
com.dessci.MathType.plist
com.dessci.MathType.plist.lockfile
Hope this helps you?
Thanks
Laura
  • March 7, 2014
Thanks for this thread! Funny that those .plists don't get captured by a normal snapshot scan. Weirder things have happened, I suppose. Anyhow, this thread saved me a bit of package troubleshooting. Cheers!
@Bray How do you ensure the license files are packaged? And thank you for the help!
