Installing "NoMAD" and "NoMAD Login AD" on the same machine
  • January 5, 2019
  • 5 replies
  • 44 views
Can the open source programs "NoMAD" and "NoMAD Login AD" be installed and used on the same machine? Or are they meant to be installed and used separately?
dpertschi
Forum|alt.badge.img+19
  • January 5, 2019
Absolutely. NoMAD will keep your password in sync after you login with NoMAD Login.
Excellent presentation from this past year JNUC using the two together.
https://youtu.be/dImloxKIb0o
  • January 5, 2019
Here are two articles that I found on incorporating Nomad login with a DEP setup.
https://sponas.no/how-to-apple-mac-dep-enrollment-with-jamf-and-nomad-login/
https://nstrauss.info/posts/nomlad-login-jamf-dep-workflows/
In my environment, I have a "create new user policy". It creates a standard account by installing Nomad Login and uninstalls it on AD account login. Standard Nomad stays installed for all users.
Profile Creator is a great tool to adjust Nomad and Nomad login to your environment.
https://github.com/erikberglund/ProfileCreator
  • May 1, 2019
@shaquir @dpertschi If both are installed and a new user is logging in to the Nomad Login window for the first time with a one-time password that needs to be updated at next login, will Nomad update this password? I currently only have Nomad Login installed and the password change is failing.
  • August 25, 2019
Hi
Does Nomad support off site log-in?
  • August 25, 2019
@PE2000 only if your AD is externally accessible.
