Installing Silverlight?
  • May 16, 2014
  • 10 replies
  • 23 views
Hello,
We are trying to update our Silverlight installs to 5.1.30317.0. In the past I would just download the DMG and pull out the Silverlight.pkg file. I would then rename the PKG to include the version number. In this case: Silverlight.5.1.30317.0.pkg. Then I would upload this PKG to Casper Admin, update the Policy and all would be fine. This most recent time, most (probably 95%) of the clients trying to install get the error
Downloading Silverlight.5.1.30317.0.pkg...
Verifying package integrity...
Installation failed. The package could not be verified.
Though a very small handful actually install successfully. We are running Casper 9.31, and I am using Admin 9.31. Do I need to go the full Composer route to install Silverlight now?
  • May 16, 2014
I am having exact same issue, if you look in CasperAdmin notice the Checksum for Silverlight has an MD5 error.
  • May 16, 2014
Ahh yes, I had to resize all of the columns to finally see what that said. ```
Index.bom: No such file or directory
bentoms
Forum|alt.badge.img+35
  • May 16, 2014
@bthomason, the checksum should be generated via Casper Admin when uploading a package into Casper Admin 9.3x.
So it's a bit odd if it's invalid, but do you need to verify the checksum? You can remove that requirement.
  • May 19, 2014
@bentoms, do you remove it in the JSS Settings under Security?
bentoms
  • May 21, 2014
  • May 21, 2014
Hello, we are not using JDS and we have not run the migration yet either.
  • May 22, 2014
@bentoms no we are not using JDS, I'm on 9.31
I have seen similar issues when packages were downloaded via SelfService. Check if you have any faulty downloaded packages in "/Library/Application Support/JAMF/Downloads". If so, remove those and try to install again.
  • May 22, 2014
I'll add now, that we finally went ahead with the Migration in Casper Admin. After doing that I re-added the Silverlight package and it uploaded successfully and created the checksum properly.
Forum|alt.badge.img+15
  • May 22, 2014
Removing the package and re uploading it will avoid the issue. One cause of this problem is that the MD5 checksum is wrong. Right click the package in Admin and choose Calculate Selected Package Checksum.
