Intermittent login issues on macOS 15.1.1
  • December 11, 2024
  • 82 replies
  • 1857 views
Show first post
  • January 7, 2026
Yes, it does reset the file live.  So almost certainly better than just deleting it if you’re trying to run something periodically I’d imagine.
If the issue isn’t strictly related to the size of the file, I don’t know if that would actually prevent things necessarily, but I’m currently guessing it is.
Not sure if there is a way you could use that to fix a broken machine.  Doesn’t seem like our startup/login scripts or management tools are especially running on the broken ones.  People above mentioned being able to ssh into broken ones, but we don’t have that set up.  Could maybe run it that way.​​​​  But no idea if it’d still work and actually reset anything if the machine is already in the broken state.
Next time I see it I will see if it works via SSH. Meantime I will use the command in a script. Thanks for sharing your results here, the sfltool resetbtm command is extremely helpful.
  • January 7, 2026
I have created a configuration profile to reset BTM on log in for each user. Still testing but so far nothing has gone wrong and it has shown the btm file was modified at log in.
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>PayloadContent</key> <array> <dict> <key>PayloadType</key> <string>com.apple.launchagent.managed</string> <key>PayloadVersion</key> <integer>1</integer> <key>PayloadIdentifier</key> <string>com.user.resetbtm.launchagent</string> <key>PayloadUUID</key> <string>8E5B3C1D-1111-2222-3333-444455556666</string> <key>PayloadDisplayName</key> <string>Reset BTM LaunchAgent</string> <key>Label</key> <string>com.user.resetbtm</string> <key>ProgramArguments</key> <array> <string>/usr/bin/sfltool</string> <string>resetbtm</string> </array> <key>RunAtLoad</key> <true/> </dict> </array> <key>PayloadDisplayName</key> <string>Reset BTM at Login</string> <key>PayloadIdentifier</key> <string>com.user.resetbtm.profile</string> <key>PayloadRemovalDisallowed</key> <false/> <key>PayloadType</key> <string>Configuration</string> <key>PayloadUUID</key> <string>12345678-AAAA-BBBB-CCCC-1234567890AB</string> <key>PayloadVersion</key> <integer>1</integer> </dict> </plist>
If you are able to test let me know how it goes please.
davidwalton
  • January 9, 2026
We are having this same issue too — But only in one of our labs. I can also confirm that SSH’ing in and reseting the BTM appears to resolve the issue.
What I’m taking away from ​@spgriffin is that size alone doesn’t indicate that the BTM is corrupted, but it sounds like size can be a solid indicator of corruption. I created an extension attribute that reports the size of the BTM stores for our machines and I’m still waiting for everything to inventory, but it seems like the lab having issues tends to have the largest BTM sizes (7-8MB).
I exported the btmdump for the problematic lab (though we don’t have a machine currently experiencing the hanging login) and compared it to a machine in a lab with a different configuration which hasn’t had the issue.
This is technically circumstantial, but it seems like the problematic lab both had a high number of “Creative” apps (like Adobe CC, Wacom, Avid, etc.) which tend to have a number of helper application, and it also had a significantly higher number of users. Like spgriffin said, btm entries are effectively duplicated per each user, so many users can fill up the btm quickly.
Something interesting: We had one machine that actively had the hanging login screen issue. I ssh’d in to perform a btmdump and it never completed. I waited several minutes. The SSH session eventually borked and I had to restart the machine. Upon restart, the BTM appeared to have been automatically reset (0mb).
spgriffin
  • January 14, 2026
If anyone’s curious -
I wiped the disk and did a clean install of 26.2 on a machine, then ran a script to create plists for 1000 background tasks in /Library/LaunchAgents.  I then created 10 local users and logged into them one at a time.  The machine broke on the 7th.
Hopefully that’s finally reproduceable enough for the Apple guy I’ve been talking to to forward it somewhere.
Stuart_P
  • January 21, 2026
Annoyingly, trying to be pro-active and running the command semi-frequently via Jamf…
/usr/bin/sfltool resetbtm
… it won’t work silently as it requires user permission.  Hopefully Apple can reproduce and resolve (from above post) - although I won’t hold my breath.
spgriffin
  • February 2, 2026
Yeah…. - that does unfortunately seem to be the case. :/  I was able to use the dumpbtm command via script and assumed that resetbtm would work similarly.
Apple did eventually “...confirm that the behavior reported in this case is currently expected and that the Product Engineering team is considering addressing it in a future OS Build” - so there’s that at least.
  • February 18, 2026
Just chiming in to say I’ve seen this behaviour across our labs.. seemed to start in Sonoma, with changes to the ‘welcome to this Mac’ & Apple Intelligence push after OS upgrades.
After never having enough time to find a root cause, I just assumed it was down to these new ‘improvements’.
I see it happening in all builds of Sonoma, Sequoia & Tahoe. Will be interesting to see if Apple address it.
