Interrogating the JSS with bash script - HELP!
  • November 27, 2012
  • 6 replies
  • 43 views
Forum|alt.badge.img+23
What i'm trying to do is to run a query in our firstrun script, on the JSS for the Mac it's currently running on. All it's trying to do is to see if the department and building settings are correctly configured. (Our JSS occasionally doesn't configure these fields properly via prestage imaging.) If they are, it skips a section of code that would give a menu choice. Here's what i've got so far (in a highly simplified version):
JSSUSR="x"
JSSPWD="x"
JSSURL=$( /usr/bin/defaults read /Library/Preferences/com.jamfsoftware.jamf.plist jss_url )
JSSPATH="JSSResource/computers/macaddress"
MACMAC=$( networksetup -getmacaddress en0 | awk '{print $3}' | sed 's/:/./g' )
BUILDING=$( curl -s -u $JSSUSR:$JSSPWD $JSSURL$JSSPATH/$MACMAC | xpath //computer/location/building/text | sed -e 's/<building>//;s/</building>//' )
DEPT=$( curl -s -u $JSSUSR:$JSSPWD $JSSURL$JSSPATH/$MACMAC | xpath //computer/location/department/text | sed -e 's/<department>//;s/</department>//' )
if [[ $BUILDING == "" || $DEPT == "" ]] ;
then
  *code here*
I've redacted our api readonly account name and password for security.
The idea is that if either or both of the two fields are blank, the script in the if statement should run. If not, it skips and gets on with the rest of the firstrun script.
What actually seems to happen is that the code in the if statement executes regardless! That's not such a bad flaw at this stage, but it's something i'd like to correct. Any thoughts?
Best answer by jarednichols
Have a look at this: http://www.linuxtopia.org/online_books/advanced_bash_scripting_guide/tests.html
It's a great resource.
Here's the front page of the guide http://www.linuxtopia.org/online_books/advanced_bash_scripting_guide/
  • November 27, 2012
I think you may want to instead do
if [ -z $BUILDING]
In the database, for that record, if the building or department aren't set, they should be NULL. You can verify this by looking in your database with read-only access and MySQL Workbench. You want to check to see if $BUILDING is NULL, not if it's empty. There's a difference.
  • November 27, 2012
That's pretty cool. Is there a way to check if either or both of them is NULL?
e.g.
if [ -z $BUILDING ] || [ -z $DEPT}
  • December 11, 2012
Sure can. Except I don't think you want a curly brace at the end there. That'll trip you up for sure.
Forum|alt.badge.img+31
  • December 11, 2012
Double ampersands is the answer here if you want to test two things in a if then statement
if [[ -z var1 ]] && [[ -z var2 ]]
then unix stuff happens here
else we stop or do other Unix stuff
  • December 12, 2012
  • January 19, 2013
We ended up giving up and not using the check after we abandoned all use of prestage imaging configuration. Thanks anyway!
