iPads - installing Okta plugin for Chrome
  • August 23, 2024
  • 32 views
Looking for some assistance in configuring iPads so that the Okta plugin is automatically installed into Chrome. Under Mobile Devices : Mobile Device Apps I select Chrome and navigate to the App Configuration Screen. In the Preferences field I believe we need to create a PLIST file and copy the code into this field. Has anyone created a PLIST for Okta's Chrome Plugin for Ipads. I keep getting failures trying to create the PLIST. Any assistance is greatly appreciated. Thx
1 reply
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • August 23, 2024
Do you mean extensions? Last I was aware, Google Chrome for iOS or iPadOS doesn't support extensions. This is a security limitation imposed by Apple.
