Is there a way to enroll by serial number without DEP?
  • August 26, 2019
  • 24 views
I want to give permission to user initiate enrolment to only company owned macs which are not in DEP. I have their serial numbers. Is there any extension attribute which can check devices serial numbers by listed serial numbers within extension attribute?
  • August 26, 2019
You'd have to create this yourself, this is exactly what DEP is designed to do. You could create an enrollment policy that runs a script to perform a check against a list, or an extension attribute script that will flag the device for action (like running a removeFramework).
bradsschroeder
I have updated the tag from Jamf Nation to Scripts and DEP to more closely match the discussion at hand.
