Morning. Was hoping someone could provide some direction here.
I created a static computer group called "Archive" to keep track of all retired computers.
I imported these machines by serial number using the MUC tool. All seemed to be going well. I then ran an action on that group to remove management from any machines in it. Also seemed to work well.
The other day, I was updating inventory and added a couple more machines to that archive group. As it was only a couple (7) machines, I just did this manually through the JAMF portal.
Now JAMF only shows 7 machines in that group, and I cannot seem to add the machines back in (manually) that were added with the MUC tool. The machines still appear in the JAMF portal as unmanaged, but I cannot add them back in. I'm assuming they don't appear when I search to add them to the group because they are set to unmanaged. Is the MUC tool the only option to add them back in this case? Or is there another issue?
