Issues using policy with mount AFP script
  • January 30, 2014
  • 39 views
We have the following script running under a policy at startup and it works great.
echo "username attempting to mount a share"
# Mount share
sudo -u username /usr/sbin/jamf mount -server servername -share sharename -type afp -username username -password password
Problem is that if we happen to login as any user, then logout, for some reason the mount goes away. Anyone know why? Is it OS X doing this? Anyway around it? Do I have to create a logout policy to remount it?
Thanks.
Mark
  • January 30, 2014
Hey @mhatch14
Pretty sure this is an OS X issue. Think you need to change a preference file:
sudo defaults write /Library/Preferences/SystemConfiguration/autodiskmount AutomountDisksWithoutUserLogin -bool YES
  • January 31, 2014
I think you're right that it's an OS X issue. The issue being that when a user logs off, all processes related to that user, including volumes mounted via AFP, are ended.
In this case, I use Casper to mount an AFP volume as a user at startup. So even if no one logs in, the machine mounts this volume via AFP. Even if I login, the volume stays mounted. The moment I logout then the volume goes away. This is the behavior that I don't want.
I would like the volume to stay mounted.
I did try the preference that you sent me and unfortunately it did not change the behavior.
Thanks.
Marl
