Jamf Compliance Editor 1.4 cant seem to create a project folder
  • September 24, 2024
  • 90 views
Hi all,
I've tried to install JCE 1.4 on a fresh laptop => selected macos => clicked on create new project => selected sequoia => clicked create => selected the folder => clicked save.
Next step would be to be prompted for a security standard, but nothing happens.
I tried it on 2 different laptops with the following OS:
Sonoma 14.7
Sequoia 15.0
I also tried selecting the following OSs for the projects:
Sonoma
Sequoia
With the same results.
Can someone please confirm that its also happening for them?
Thx!
  • October 1, 2024
@etmekehallpass wrote:
Hi all,
Sonoma 14.7
Sequoia 15.0
Sonoma
Sequoia
Thx!
If you're encountering an issue with JCE 1.4 not prompting for a security standard after creating a new project. This could be related to compatibility with macOS Sonoma or Sequoia. First, ensure that you have the latest version of JCE installed, as updates may fix known issues.
mrsimon007
  • January 21, 2026
It looks like you’re not alone. A few users have reported the same issue where JCE 1.4 doesn’t proceed to the security standard step after creating a new project on recent macOS versions. This seems to be a compatibility or UI bug rather than a setup mistake. Hopefully it will be addressed in an update.
