Today we released Jamf Connect 2.1.1 for general availability; this release includes the below bug fixes.
Configuration Bug Fix: Removed an extraneous button that could be added to the toolbar which acted the same as the Test button.
Login Window Bug Fixes:
• [PI-008978] Fixed an issued that caused Jamf Connect to display a grey screen when a custom login window message and an Apple policy banner were both configured.
• [PI-008987] Fixed an issue that caused the Jamf Connect login window to freeze after entering the FileVault password when FileVault is enabled on computers, an Acceptable Use Policy screen was configured to display, and Require Network Authentication (DenyLocal) was disabled.
• [JC-2126] Fixed an issue that caused the local help file, when configured, to unexpectedly display for about two seconds after a successful network authentication.
Menu Bar App Bug Fix: Fixed an issue that prevented password sync prompts from displaying on Big Sur if Enable Automatic Sign-in(AutoAuthenticate) was enabled.
Product Documentation
For more information, including Release Notes, please see the Jamf Connect Administrator Guide.
Thank you!
The Jamf Connect team
Hi, thanks for continuous effort in improving JAMF Connect. Any plans when this will be visible in Patch Management? Even 2 days after I still see as latest version 2.1.0.
Thanks
2.1.0 / 2.1.1 ??
I still only have 2.0.2 as latest version in Patch Management.
(and 10.15.7 for macOS)
