Hey everyone,
Is there any good resources on how to setup/test Connect?
I've confirmed that the Azure AD Client ID and tenant info are correct when using the Jamf Connect Config tool. It gives me tokens for OIDC and ROPG and shows successful each time. I also can confirm there is a login entry within Azure for the user.
I read that it's best to have 3 config profiles pushed to the device: Connect, Login, and License.
However, the license isn't applied and sign in is greyed out.
Is there any best practices/guide that could be shared?
I put the license in the Connect and Login profiles. I'm not sure if it's best practice but it works.
You can install the license in different ways. A stand-alone profile does seem to work the best.
You can also add it in the UI if you use the jamf application config portion for jamf connect.
But if you get stuck reach out to Jamf success they should help you!
 or:
you need to have config profile for Jamf app , login window and i have recent setting up jamf connect and succeeded
