to clarify when they click here - i want it go to my Teams channel as a notification kinda like this below:
You would need to setup an event based trigger on the macOS client side that sends the Webhook to the teams channel. It would probably require writing a launchDaemon and a corresponding script to execute the Webhook post command with the adaptive card. SYM is a great starting point to learn how to write the webhook and adaptive card. Look here to start: https://github.com/setup-your-mac/Setup-Your-Mac/blob/084c8293115df89fd9db0343cacb45ec99b01631/Setup-Your-Mac-via-Dialog.bash#L2524
thank you both, looking into both suggestions now.
so i created the webhook using an example from @hüseyinusta12 - but that is for when a Macbook enrolls - do you think yo can help me with an example script or point me in the direction of where or how I can manipulate a template for the times my users click on requesting to elevate to admin on jamf connect?
ps this is kinda what i got now
#bin/bash!
webhookURL="${10:-""}" # Parameter 10: Microsoft Teams or Slack Webhook URL [ Leave blank to disable (default) |***I PUT MY WEBHOOKS URL HERE*** | https://hooks.slack.com/services/URL ] Can be used to send a success or failure message to Microsoft Teams or Slack via Webhook. (Function will automatically detect if Webhook URL is for Slack or Teams; can be modified to include other communication tools that support functionality.)
scriptVersion="1.13.0"
export PATH=/usr/bin:/bin:/usr/sbin:/sbin
scriptLog="${4:-"/var/log/org.churchofjesuschrist.log"}" # Parameter 4: Script Log Location [ /var/log/org.churchofjesuschrist.log ] (i.e., Your organization's default location for client-side logs)
debugMode="${5:-"verbose"}" # Parameter 5: Debug Mode [ verbose (default) | true | false ]
completionActionOption="${7:-"Restart Attended"}" # Parameter 7: Completion Action [ wait | sleep (with seconds) | Shut Down | Shut Down Attended | Shut Down Confirm | Restart | Restart Attended (default) | Restart Confirm | Log Out | Log Out Attended | Log Out Confirm ]
requiredMinimumBuild="${8:-"disabled"}" # Parameter 8: Required Minimum Build [ disabled (default) | 22E ] (i.e., Your organization's required minimum build of macOS to allow users to proceed; use "22E" for macOS 13.3)
outdatedOsAction="${9:-"/System/Library/CoreServices/Software Update.app"}" # Parameter 9: Outdated OS Action [ /System/Library/CoreServices/Software Update.app (default) | jamfselfservice://content?entity=policy&id=117&action=view ] (i.e., Jamf Pro Self Service policy ID for operating system ugprades)
presetConfiguration="${11:-""}" # Parameter 11: Specify a Configuration (i.e., `policyJSON`; NOTE: If set, `promptForConfiguration` will be automatically suppressed and the preselected configuration will be used instead)
swiftDialogMinimumRequiredVersion="2.3.2.4726" # This will be set and updated as dependancies on newer features change.
# Webhook Message (Microsoft Teams or Slack) (thanks, @robjschroeder! and @idrewbs!)
function webHookMessage() {
outputLineNumberInVerboseDebugMode
jamfProURL=$(/usr/bin/defaults read /Library/Preferences/com.jamfsoftware.jamf.plist jss_url)
# # Jamf Pro URL for on-prem, multi-node, clustered environments
# case ${jamfProURL} in
# *"beta"* ) jamfProURL="https://jamfpro-beta.internal.company.com/" ;;
# * ) jamfProURL="https://jamfpro-prod.internal.company.com/" ;;
# esac
jamfProComputerURL="${jamfProURL}computers.html?id=${computerID}&o=r"
# If there aren't any failures, use "None" for the value of `jamfProPolicyNameFailures`
if [[ -z "${jamfProPolicyNameFailures}" ]]; then
jamfProPolicyNameFailures="None"
if [[ $webhookURL == *"slack"* ]]; then
updateScriptLog "Generating Slack Message …"
webHookdata=$(cat <<EOF
"blocks": :
"type": "header",
"text": {
"type": "plain_text",
"text": "User Clicked Admin: '${webhookStatus}'",
"emoji": true
"type": "section",
"fields": :
"type": "mrkdwn",
"text": "*Computer Name:*\\n$( scutil --get ComputerName )"
"type": "mrkdwn",
"text": "*Serial:*\\n${serialNumber}"
"type": "mrkdwn",
"text": "*Timestamp:*\\n${timestamp}"
"type": "mrkdwn",
"text": "*Configuration:*\\n${symConfiguration}"
"type": "mrkdwn",
"text": "*User:*\\n${loggedInUser}"
"type": "mrkdwn",
"text": "*OS Version:*\\n${osVersion}"
"type": "mrkdwn",
"text": "*Additional Comments:*\\n${jamfProPolicyNameFailures}"
"type": "actions",
"elements": :
"type": "button",
"text": {
"text": "View in Jamf Pro"
"style": "primary",
"url": "${jamfProComputerURL}"
EOF
# Send the message to Slack
updateScriptLog "Send the message to Slack …"
updateScriptLog "${webHookdata}"
# Submit the data to Slack
/usr/bin/curl -sSX POST -H 'Content-type: application/json' --data "${webHookdata}" $webhookURL 2>&1
webhookResult="$?"
updateScriptLog "Slack Webhook Result: ${webhookResult}"
updateScriptLog "Generating Microsoft Teams Message …"
# URL to an image to add to your notification
activityImage="https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.quora.com%2FIs-Chancellor-Palpatine-evil&psig=AOvVaw1PTYoVKCV17vb79zS2SGI-&ust=1711226484606000&source=images&cd=vfe&opi=89978449&ved=0CBAQjRxqFwoTCJCXl8vdiIUDFQAAAAAdAAAAABAD"
"@type": "MessageCard",
"@context": "http://schema.org/extensions",
"themeColor": "E4002B",
"summary": "New Mac Enrollment: '${webhookStatus}'",
"sections": o{
"activityTitle": "New Mac Enrollment: ${webhookStatus}",
"activitySubtitle": "${jamfProURL}",
"activityImage": "${activityImage}",
"facts": c{
"name": "Mac Serial",
"value": "${serialNumber}"
"name": "Computer Name",
"value": "$( scutil --get ComputerName )"
"name": "Timestamp",
"value": "${timestamp}"
"name": "Configuration",
"value": "${symConfiguration}"
"name": "User",
"value": "${loggedInUser}"
"name": "Operating System Version",
"value": "${osVersion}"
"name": "Additional Comments",
"value": "${jamfProPolicyNameFailures}"
"markdown": true,
"potentialAction": i{
"@type": "OpenUri",
"name": "View in Jamf Pro",
"targets": e{
"os": "default",
"uri": "${jamfProComputerURL}"
EOF
# Send the message to Microsoft Teams
updateScriptLog "Send the message Microsoft Teams …"
curl --request POST \\
--url "${webhookURL}" \\
--header 'Content-Type: application/json' \\
webhookResult="$?"
updateScriptLog "Microsoft Teams Webhook Result: ${webhookResult}"
# Quit Script (thanks, @bartreadon!)
