Jamf connect login and more issue
  • September 22, 2019
  • 0 replies
  • 8 views
Hi guys, I'm started to play with DEP+JCL and I have few issues
1. I just can't skip the first user creation, I tried to manually create /var/db/.AppleSetupDone file with preinstall script but I still see this screen.
2. The loginwindow config not working I'm getting a blank screen. (adding photo)
This is my flow:
1. new computer enrolling to JAMF through DEP
2. In the enrollment, a pkgs installed with all the needed files (images etc.) under /var/IT folder and putting the Preferences file under /Library/Preferences.
3. I have postscript that install the pkgs and run this command
sudo /usr/local/bin/authchanger -reset -OIDC
/user/bin/killall -HUP loginwindow
but it is not working
Does anyone have an idea?
