JAMF Connect ROPG Failure
  • December 15, 2025
  • 4 replies
  • 126 views
shikhartodaria
HI everyone,
I am trying to implement JAMF Connect in our organization. I was able to successfully configure the OIDC, but while testing the ROPG, I am getting the attached error.
I have confirmed that the client secret ID is correct, as the ROPG login is working for just one account. Also, all the users have been given access to the Enterprise Application.
Any leads would be helpful.
Thanks
Chubs
Forum|alt.badge.img+23
  • December 15, 2025
How did you configure the plists?  And yes, you’ll need two (Jamf Connect and Jamf Connect Login).
shikhartodaria
  • December 24, 2025
The configuration works, but only for the accounts that were created directly on Entra. none of the AD synced accounts are working.
Chubs
  • December 24, 2025
Are you using ADDS to create accounts and leveraging ADFS?
shikhartodaria
  • February 16, 2026
JAMF confirmed that ROPG does not work with Federated accounts. So, we will have to make do with OIDC only.
