Jamf Imaging problems with 10.3.0 ?
  • March 27, 2018
  • 23 replies
  • 50 views
Anyone else having issues with Jamf Imaging?
We can login to Jamf Imaging just fine, load all configurations etc but as soon we press the button to Image an error will appear telling "Unable to create invitation. Check to make sure you have permission etc etc etc.. "
we do have the permissions required and as soon I downgrade to the previews version imaging is working again..
Just wondering if there's anyone else having this error?
  • 58 replies
  • March 27, 2018
I have the same issue. I even checked that the option to "Require login for PreStage Imaging and Autorun imaging" is not checked.
  • 4 replies
  • March 27, 2018
Yes. I too am having the exact same issue. And, it started after I upgraded to JAMF Pro 10.3.0. I have a ticket in with JAMF Support. I will certainly update here if we figure anything out.
ehemmete
  • 13 replies
  • March 27, 2018
Is this an issue with JSS v10.3 or JAMF Imaging v10.3? i.e. if you use JAMF Imaging 10.2.x with your JSS v10.3 do you still have the issue?
  • 58 replies
  • March 27, 2018
This seems to be more an issue with 10.3 Jamf Pro and not Jamf Imaging.
ImAMacGuy
Forum|alt.badge.img+23
  • 1310 replies
  • March 27, 2018
I was on an unrelated support call and brought this thread to my account reps attention.
  • 1143 replies
  • March 27, 2018
not trying to be jerky, and it's not going to be relevant much longer with imaging dying, but imaging can be tested pre upgrade in a test environment. It's part of my upgrade checklist that might be helpful to some. Might help ease some of the pain of upgrades.
garybidwell
Forum|alt.badge.img+15
  • 178 replies
  • March 28, 2018
I can confirm this happens in our 10.3 Development environment tested using both 10.2.x and 10.3 versions of the Jamf Imaging apps..
  • 1143 replies
  • March 28, 2018
@gbidwell we're imaging fine with 10.2.1 in production. I won't test 10.3 until it's been out a few weeks in case 10.3.1 is rushed out to fix some issue.
Edit: nevermind now i see what you're saying. Your development is 10.3 and you were testing various versions of apps. Got it, sorry.
  • 4 replies
  • March 28, 2018
I got a response from JAMF Support this morning that cleared up the problem for me. Whatever account you are using for imaging cannot have a password with non-alphanumeric characters in it. Once the password is changed to one that is strictly letters and numbers, JAMF Imaging works just fine. I am assuming that this is a glitch that JAMF will fix soon, but at least imaging can happen until then. Granted, imaging as a whole is definitely on the way out, but I am glad I have it operational again, especially for the older Macs in my school.
  • 79 replies
  • April 2, 2018
I have passwords that are only Alphanumeric and the issue persists.
  • 13 replies
  • April 3, 2018
Any response from JAMF about a fix for this? I am holding off on upgrading until this is fixed. This really should be addressed ASAP since it BREAKS imaging, which worked fine.
ImAMacGuy
  • 1310 replies
  • April 3, 2018
I cancelled my upgrade too. I don't think any of our techs use special characters, but it's not worth the headache if they do.
  • Employee
  • 22 replies
  • April 3, 2018
Jamf is aware of this issue and currently reviewing both workarounds and finding a fix.
  • 35 replies
  • April 13, 2018
Wow... what is it with Jamf and "good" passwords. This is not the first time we've run into a bug related to passwords,
Data point for other folks, removing the non-alpha-numeric (aka things that make good passwords) digits from my password solved the problem for us.
  • 8 replies
  • April 16, 2018
It turns out that a special character in the username will also trigger this bug. So, both username and password must not contain non-alphanumeric characters. It's still possible to conform to MS complexity requirements (3 out of 5): Upper character, Lower character, and Number. However, this bug is still silly.
  • 36 replies
  • May 1, 2018
  • 8 replies
  • May 1, 2018
The special characters PI was patched in Jamf Pro 10.4.0.
http://docs.jamf.com/10.4.0/jamf-pro/release-notes/Bug_Fixes_and_Enhancements.html
Jamf Imaging [PI-005660] Fixed an issue that caused an error to display when imaging computers using Jamf Pro administrator passwords containing special characters. Note: When interacting with the Jamf API, the encoding for credentials must be UTF-8. Failure to use this encoding may cause authentication issues with the Jamf API when the username or password contain certain international characters.
  • 19 replies
  • May 1, 2018
Anyone know if this was fixed in the new 10.4 release?
gabe2385
  • 59 replies
  • May 2, 2018
Hey @raven.dover I just tried it on our Dev environment and it looks like it is working fine on 10.4
  • 19 replies
  • May 2, 2018
Ok so the 10.4 update did NOT fix the issue for me. I have to remove special characters from my login.
I will submit a bug notice.
  • 36 replies
  • May 2, 2018
@raven.dover i'd file a support ticket if i were you - you may be dealing with something else entirely. Hope you figure it out!
  • 19 replies
  • May 2, 2018
haha already done!
  • 7 replies
  • May 4, 2018
Never mind it did work for me. I had to put JAMF Imaging 10.4 on my boot stick to image.
