Jamf Pro 10.3.1 Maintenance Release Now Available
  • April 10, 2018
  • 30 replies
  • 155 views
A maintenance release of Jamf Pro is now available. Jamf Pro 10.3.1 fixes an issue that caused mobile devices to remain in a failed MDM loop when using the Jamf Pro "Update iOS Version" remote command to push iOS 11.3 updates to devices due to changes with the MDM Software Update workflow. Any devices in a failed loop state will have their MDM communication restored after upgrading to Jamf Pro 10.3.1 or later.
You can download updated installers from Jamf Nation in the "My Assets" section. Cloud instances will be upgraded starting April 13th to the 14th, depending on your hosted region. A separate email details when your instance will be upgraded. If you have any questions about this release, or anything else, please do not hesitate to reach out. For more information about Jamf Pro 10.3.1, please review the release notes.
bpavlov
  • April 10, 2018
Not asking on my behalf, but I figured others are going to ask. Is there going to be a patch for customers on v9.101? An official answer would probably be appreciated by customers.
I'm going to guess the answer is no. I'm perfectly fine with that since we're on v10 already and it makes less sense to dedicate software engineering resources to backtrack changes to a previous version of a product.
ImAMacGuy
Forum|alt.badge.img+23
  • April 10, 2018
and the special characters bug for imaging is not addressed either?
bpavlov
  • April 10, 2018
ImAMacGuy
  • April 10, 2018
I saw that it wasn't listed, I was asking again for formal clarification.
  • April 10, 2018
We really would like to know if the Imaging issue (authentication / invitation) is fixed. This is really a significant problem.
Dan
  • April 10, 2018
Considering imaging is a major component of the software that is broken, I sure hope it was fixed and not JUST an IOS issue.
boberito
Forum|alt.badge.img+22
  • April 10, 2018
Awesome to hear I'm not alone with imaging being broken and finding that excruciatingly annoying.
mojo21221
  • April 10, 2018
I haven't tested 10.3.1 yet to see if imaging has been fixed. But my current work around for 10.3 is to make a standard account with a password that is only characters and numbers. Then share that to the team doing imaging for a temporary workaround.
example username = imaging
example password = 1234qwer
  • April 10, 2018
@bpavlov No. Jamf has made it clear to me they will not be doing further development work on version 9. I've been through denial, anger, bargaining, depression, and, finally, acceptance. We're updating to Jamf Pro 10.3.1 this Thursday for better or worse. Initial testing has been positive. Fingers crossed!
  • April 10, 2018
@mojo21221 That is what we did for a work around as well. It works, but it certainly isn't the best solution. I was really hoping that the update would fix the issue.
  • April 10, 2018
We are still running 10.2.2. Will be interested to hear from anyone running 10.3.1 to see how well it works for them. It sounds like the imaging thing can be worked around with an imaging password with no special characters. I'm not sure I've heard about any other issues.
  • April 10, 2018
Looks like I am not the only one with Imaging "invitation" issues. I hope it will be fixed soon.
gabe2385
  • April 11, 2018
Just updated this morning on our development server to 10.3.1 and as you can see the Jamf Imaging issue has not been resolved for. I Also noticed when opening the Jamf Imaging app and when it goes into the authenticate box to the Jamf Pro Server, the username and password boxes don't show the cursor, you can type but then when you tab it doesn't go to the next line you actually have to click on the password box to go to the next one. I only saw it on Jamf Imaging the other apps seems fine. I tried it on multiple machines etc. etc. Still up in the air if we are going to update and do the work around of creating a standard user for imaging.
  • April 11, 2018
I tried to download the latest version. Somehow I keep getting 10.3.0-t1521825567 instead of the announced version. Tried the root.war file in the Apple installer and the root.war file from the manual install.
I'm puzzled?!
edit: After some backtracking: I did download the latest version and that is the 10.3.1 version. In my installation environment I forgot to update the version number so the old warfile got installed. No panic, all's well :-)
  • April 11, 2018
Thanks for the update. Facing this issue currently.
  • April 12, 2018
My db server has been blowing up ever since running this update. Normally, CPU is around 4% - 10% and InnoDB hovers around 60%. It's been pushing data all night. Have a ticket in but wondering if anyone else has seen this?
- Nothing else in the environment appears to have changed. My environment variables for Tomcat appear to be untouched.
  • April 12, 2018
Sorry I'm a newbie, what does it mean to remain in a failed MDM loop?
  • April 12, 2018
@kmorrow Basically, the iOS devices trapped in the loop wouldn't/couldn't report inventory back to the JSS. So, if the JSS (the MDM), can't read-out the devices' state it can't manage it. If the device can't/won't report it's state, it can't be managed - in so far as new MDM commands are issued. ...the device just loops on it's last executed command and is "stuck" until the report of it's state is sent/received.
  • April 12, 2018
@gabe2385 On that dev server if you run 'truncate enrollment_inviations;' on the jamfsoftware db, and the restart Tomcat, do you see the same error? With backups if you need them before of course.
I ask because when I upgrade to 10.3, mine fails due to failure to migrate enrollment invitations. The workaround in support was to truncate that table. Just tested imaging in my dev instance, and it works fine.
  • April 12, 2018
@chris.miller I definitely noticed 10.3.1 being slower than 10.3 in my testing. Are you seeing that in an upgrade from 10.3 to 10.3.1? Or from an earlier version than that?
  • April 12, 2018
@chris.miller Did you get a response to your ticket ? I was thinking of updating but your post isn't instilling me with confidence.
gabe2385
  • April 13, 2018
@lashomb , I tried to run the 'truncate table enrollment_invitations;' command and it did not work for me. Maybe I will reach out to support next week and they have something else up there selves.
@gabe2385
if username or password contains any special characters you will receive that error.
  • April 16, 2018
@gabe2385 We are seeing this too now unfortunately. We're just working around it using local account for imaging.
@chris.miller What are you using to monitor in that screenshot?
