Jamf recon stalls / stuck at Locate Hardware Information
  • April 4, 2025
  • 406 views
Hi Everyone
I'm getting "Locate Hardware Information" stuck on one macbook air M4 laptop whilst tring to execute sudo jamf recon, i followed the steps and instructions found on https://community.jamf.com/t5/jamf-pro/jamf-recon-stalls-at-locate-hardware-information/td-p/315285 and https://community.jamf.com/t5/jamf-pro/recon-hangs-on-locating-hardware-information/m-p/284704 but when we execute the "sudo launchctl kickstart -k system/com.apple.softwareupdated" it fails with the error "Could not kickstart service "com.apple.softwareupdated": 150: Operation not permitted while System Integrity Protection is engaged". We then tried deleting the /Library/Preferences/com.apple.SoftwareUpdate.plist configuration file and restarting but that didnt work either. Anyone else have the same problem and or know how to resolve this?
OS: 15.4 but this also happening on 15.3.2 as well
Jamf Pro: 11.15.2
Shyamsundar
  • April 4, 2025
On Settings -> Computer Management -> Inventory collection. uncheck the Collect all available software updates, instead use the below EA to get the software update details.
#!/bin/zsh recommendedUpdates=$(defaults read /Library/Preferences/com.apple.SoftwareUpdate.plist RecommendedUpdates | wc -l | awk '{print $1}') if [[ recommendedUpdates -gt 2 ]]; then echo "<result>True</result>" else echo "<result>False</result>" fi
AJPinto
  • April 4, 2025
If you run jamf recon verbose where is it hanging? Im figuring on an Extension Attribute and verbose recon should tell you which one.
  • November 21, 2025
On Settings -> Computer Management -> Inventory collection. uncheck the Collect all available software updates, instead use the below EA to get the software update details.43321i4CBAB016FF57A922.png
Hi Shyamsundar
We running macOS 15.7 and we still have this issue where random devices stop check-in and update inventory.
Jamf Recon and Policy hang on these devices
67301 root               0.0  0.1       29:27 /usr/local/jamf/bin/jamf recon
67437 root               0.0  0.1       28:53 /usr/local/jamf/bin/jamf policy -stopConsoleLogs -runOnQueue -randomDelaySeconds 300
When running “sudo jamf recon -verbose” on this device, i dont see any issues
 verbose: Finding CoreStorage information...
Locating hardware information (macOS 15.7.2)...
 verbose: Device is BLE capable: no
 verbose: Device is SIP protected: Enabled
 verbose: Checking AD status...
 verbose: Gatekeeper status: App Store and identified developers
Submitting data to https://xxxx.jamfcloud.com/...
<computer_id>187</computer_id>
 verbose: Removing old application usage reports...
 verbose: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.task.bgrecon.plist…
Disabling “Collect all available software updates” would help in our case ?
Also is there any Pi going for this issue on macOS 15 or later.
