JamfAAD - Issue
  • May 31, 2021 12:25 PM UTC
  • 129 replies
  • 2060 views
Show first post
piotrr
  • Dec 23, 2021 7:50 AM UTC
 By the way, it turns out our infrastructure does not allow certificate issuance, so I'm stuck with the Self Service / Company Portal / Jamf AAD / browser mess.
bwoods
  • Dec 27, 2021 2:41 PM UTC
@piotrr why is your Jamf Pro server unable to issue certs?
jonn1e
  • Jan 5, 2022 12:03 PM UTC
I've build a workaround to set Google Chrome as default browser after the first deployment with DEPNotify. Then the authentication will work properly in most cases.
But please can somebody from the Jamf Support Team bring some light into this AAD cave? It's so annoying!
  • Mar 7, 2022 10:34 PM UTC
Several machines that have initially registered with Intune are now disappearing from Endpoint Manager and I have no idea why. Looks like I'll need to enable JamfAAD logging.
It seems like the AAD ID is changing on the Mac side?
  • Apr 7, 2022 6:43 PM UTC
Here is a script that I whipped up. It gets around the PI bug with the blank Safari page. All of the Macs in my environment have Chrome set as their default browser during DEP and use Chrome for Azure Device Registration. Only 6 out of 353 Macs have had this issue in my environment. 62 other Macs that were migrated from another organization work fine, just those 6 had a problem. Those 68 Macs were done via User Initiated Enrollment, as we did not have their serial numbers absorbed into Apple Business Manager prior to the migration.
These Keychain keys were mentioned somewhere in another thread.
#!/bin/bash #Current User loggedInUser=$(/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }') #Delete Keychain Access Entries sudo -u $loggedInUser -H security delete-generic-password -l "https://device.login.microsoftonline.com/ (UBF8T346G9.com.microsoft.CompanyPortalMac)" sudo -u $loggedInUser -H security delete-generic-password -l "com.microsoft.adalcache" #clean sudo -u $loggedInUser -H "/Library/Application Support/JAMF/Jamf.app/Contents/MacOS/JamfAAD.app/Contents/MacOS/JamfAAD" clean #Open Safari, prompt user to set it as default browser via jamfHelper, then registerWithIntune open -a Safari title="JamfAAD Fix" description="Please make Safari your default browser by clicking Make Safari Default within the top banner of the Safari window. After clicking Make Safari Default, click Use Safari." button1="Ok" #button2="null" jamfHelper="/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper" icon="/Applications/Safari.app/Contents/Resources/AppIcon.icns" RESULT=$("$jamfHelper" -windowType utility -windowPosition ur -title "$title" -description "$description" -icon "$icon" -button1 "$button1") #-button2 "$button2" if [[ $RESULT == 0 ]]; then sudo -u $loggedInUser -H "/Library/Application Support/JAMF/Jamf.app/Contents/MacOS/JamfAAD.app/Contents/MacOS/JamfAAD" registerWithIntune #elif [[ $RESULT == 2 ]]; then #exit 0 fi #Run gatherAADInfo sudo -u $loggedInUser -H "/Library/Application Support/JAMF/Jamf.app/Contents/MacOS/JamfAAD.app/Contents/MacOS/JamfAAD" gatherAADInfo #Close Safari osascript -e "tell application \\"Safari\\" to quit"
piotrr
  • May 31, 2022 11:41 AM UTC
10.38 appears to have finally given us an alternative, by employing WebView in JamfAAD.
New Features and Enhancements - Jamf Pro Release Notes | Jamf
I've created and deployed the script to two of my machines, but they're both already enrolled so it's not a perfect scenario. However, when rerunning the registration (which should do nothing, really) I still get a browser-branded popup asking me to continue with the registration.
Has anyone else already tried this on non-enrolled machines to see if the Webview option works?
  • May 31, 2022 1:54 PM UTC
You need to run as the logged in user for it to work. The policy in the docs did not work for me.
This script did:
loggedInUser=`/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'`
sudo -u "$loggedInUser" defaults write com.jamf.management.jamfAAD useWKWebView true
piotrr
  • May 31, 2022 1:59 PM UTC
This script did:
Running the script as the current user did save the default.
After a system restart, JamfAAD even used webview. It _had_ to be a restart though.
Now to deploy the script to the users who are having registration requests every 30 days.
jonn1e
  • May 31, 2022 2:11 PM UTC
@piotrr
There is no need for a restart?
I'm executing the script via DEPnotify before users can take action at the device. Everything is working flawless. 🙃
piotrr
  • May 31, 2022 2:17 PM UTC
@piotrr
The script, yes, but even though I have confirmed the defaults saved, running the JamfAAD registration procedure to re-register devices that have become unlinked from Intune, this _still_ starts the default web browser until a restart has been performed.
jonn1e
  • May 31, 2022 2:30 PM UTC
Hm strange, never observed this kind of behavior.
Did a few enrollments since the update.
  • May 31, 2022 7:00 PM UTC
This script did:
What about the fact the machines are already registered!.  Does the WebView still work OK? The documentation reads like net new machines only or if you wipe all the settings out then register.
I am wondering I should put the script in SS. When users call Service Desk with the issue, SD can direct the user to the Policy in SS.
astiephi
  • Jun 6, 2022 10:44 AM UTC
You can set the useWKWebView through a configuration profile, with a custom payload set to the com.jamf.management.jamfAAD domain :
And that's it !
<plist version="1.0">
<dict>
<key>useWKWebView</key>
<true/>
</dict>
</plist>
dlondon
  • Jun 8, 2022 6:18 AM UTC
@bmack99  I have implemented this in my production environment. As I mentioned in the post, you no longer have to register a device with the company portal app. You just need to deploy your MCAS cert. This also gives you full control of device compliance. You can hop over to the # jamf-intune-integration Slack channel for more information.
Hi @bwoods - do you mean you are using a device cert to control access on the network?  Or, do you mean somehow you are using the device cert for authentication for Intune?
  • Jun 9, 2022 11:06 PM UTC
I was looking to enable this today and noticed a difference between the script and the jamf docs. It looks like they added an update to the command to enable Webview. Jamf Release Notes
Has anyone had any problems deploying the prior command without the -bool or testing out the policy with the new update?
  • Jun 14, 2022 8:40 PM UTC
And that's it !
<dict>
<true/>
</dict>
</plist>
This did not work for me.
Added profile to Computer
Rebooted
Checked com.jamf.management.jamfAAD for userWKwebView entry...nada.
Manually added userWKwebView using defaults write.....the entry was there.
Tried again assigned the profile to USER.  Same issue. the entry did not appear in the plist.
Is there more to this or is this expected behaviour?
  • Jun 14, 2022 8:47 PM UTC
Rebooted
Let me change my mind.
Although there was nothing written to the plist I did experience different behaviours when I reregistered my Mac using SS and Azure, then removed the Profile and registered again.  The registration with profile (user OR device scoped) was cleaner and smoother.
  • Jun 24, 2022 2:55 PM UTC
I tried it in our environment but it didn't as expected. I was using policy to push it. @astiephi's plist via config profile worked on few pilot devices. I'm planning to expand it.
  • Jun 24, 2022 2:56 PM UTC
  • Jun 24, 2022 3:29 PM UTC
With the Webview config profile & the Microsoft Enterprise SSO plugin together deployed, we haven't received one complaint since. Works really well!
  • Jun 24, 2022 5:51 PM UTC
Sorry, I haven't tested Microsoft Enterprise SSO plugin yet. Will review Microsoft doc and try it next week. Thanks!
  • Jun 27, 2022 4:24 PM UTC
Sounds like a dream come true!
  • Jul 18, 2022 5:00 PM UTC
@vcherubino Thank you for the tip!
For those unaware, there is a documentation from Jamf about how to build the Configuration Profile (Jump to the 'Configure JamfAAD to use WebView' section):
https://docs.jamf.com/technical-articles/Troubleshooting_Microsoft_Azure_Login_Using_JamfAAD.html
I'm trying it out and see if it works. Thanks!
  • Jul 19, 2022 1:54 PM UTC
I can confirm webview is working with device registration when utilizing this config profile with the custom settings. The big question i have is if i deploy this config profile out to my fleet now will that suffice for when JamfAAD goes nuts after a pw change or inactivity etc, or does the device have to be completely re registered first?
  • Jul 19, 2022 2:10 PM UTC
From my experience, deploying new profile will be suffice. Existing enrolled Macs won't be impacted. New users will have better experience registering their device. I would recommend two additional things to minimize JamfAAD prompts:
-Increase inactivity in macOS Connector to max (120 days)
-Plan schedule cleanup for macOS devices in Azure. Support case was lodged Microsoft where Intune compliant was not able access company resources. We had to delete old Mac devices (associated to users in Azure) which helped. Here is link to doc from Microsoft [Cause 6] - Troubleshooting Jamf Pro integration with Microsoft Intune - Intune | Microsoft Docs
