Jamfhelper window won't load icon in Ventura 13.0.1
  • December 5, 2022
  • 5 replies
  • 100 views
skythrock
Having a bit of a weird issue. So I have this script that pops a notification box open on check-in, and it's working fine, except that it won't display the branding icon in the box. It's probably easier to show than to tell, so see below (executing this script in macOS Ventura 13.0.1):
jamfHelper="/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper" windowType="hud" description="Insert description here (edited for the sake of this forum post)" icon="~/Library/Application\\ Support/com.jamfsoftware.selfservice.mac/Documents/Images/brandingimage.png" #this path is accurate title="macOS Update Required" alignDescription="left" alignHeading="center" button1="OK" timeout="600" window=$("$jamfHelper" -windowType "$windowType" -lockHUD -title "$title" -timeout "$timeout" -icon "$icon" -description "$description" -alignDescription "$alignDescription" -alignHeading "$alignHeading" -button1 "$button1")
What am I doing wrong?
Best answer by skythrock
In my experience, Jamf doesn't like the current user being represented by ~
I would change this to a variable. something like...
currentUser=`/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'`
icon="$currentUser/Library/Application\\ Support/com.jamfsoftware.selfservice.mac/Documents/Images/brandingimage.png" #this path is accurate
Hopefully this helps.
Nice, thanks for this! I ended up combining yours and @YanW's suggestions. This syntax gave me the result I was looking for:
icon="Users/$loggedInUser/Library/Application Support/com.jamfsoftware.selfservice.mac/Documents/Images/brandingimage.png"
  • December 5, 2022
YanW
  • December 6, 2022
maybe try either removing the \\ between Application Support or the ""
scottb
  • December 6, 2022
Yeah, one or the other there...I've had that cause troubles with some items over the years...
skythrock
  • December 8, 2022
skythrock
  • December 8, 2022
Thanks for this tip!
