Java and xprotect
  • January 14, 2013
  • 6 views
ImAMacGuy
Forum|alt.badge.img+23
Is there a way to have an ea setup to check if its received the xprotect data for the java exploits?
1 reply
  • January 14, 2013
The following reads back the last modification date from the Xprotect plist:
defaults read /System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/XProtect.meta LastModification
But I think the better thing to look at is if the blocked plug in field for Oracle is correct. Perhaps like this?
defaults read /System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/XProtect.meta PlugInBlacklist | awk -F"= " '/com.oracle.java/{ getline; print $2 }' | sed -e 's/"//g;s/;//g'
