Java Cryptography Extension (JCE) Unlimited Strength Encryption Required. Jamf 11.7.1
  • August 13, 2024
  • 44 views
I'm trying to install JAMF 11.7.1 on a new RHEL 9 box, I'm receiving the following error,
"Verifying archive integrity... All good.
Uncompressing Jamf Pro Installer 100%
Starting the Linux Jamf Pro Installation
Checking installation requirements...
Checking for a 64-bit OS...OK
Checking available disk space...
Warning: Available disk space is below the recommended 150 GB to install Jamf Pro. Ensure your server has adequate disk space before proceeding.
Proceed? (y/n): y
Continuing installation requirements...
Executing set-java-home...
JAVA_HOME is ''...
Setting JAVA_HOME to '/usr/lib/jvm/java-21-openjdk-21.0.4.0.7-1.el9.x86_64'
Checking for Java 11...
Verifying JCE Unlimited Strength Jurisdiction Policy files...
Could not install Jamf Pro because the following requirements were not met.
For information on installing Java and MySQL, see related Knowledge Base articles on Jamf Nation.
Checking if Tomcat is running...
Passed Tomcat requirements...
Aborting installation due to unsatisfied requirements.
Installation failed. See /usr/local/jss/logs/jamf-pro-installer.log for more details."
The JCE .Jars are installed in /lib/security for the Java 21 install and I have reinstalled Java from scratch. Any Ideas?
Thanks in Advance!
1 reply
AJPinto
  • August 14, 2024
For issues installing and upgrading Jamf it is best to call Jamf.
