JSS 8.6 and Casper Suite Applications
  • August 8, 2012
  • 5 replies
  • 33 views
If I upgrade our JSS server from 8.52 to 8.6 will I still be able to user the older Casper Suite applications (i.e. Composer, Admin) or will I have to upgrade the applications as well?
  • August 8, 2012
You'll need the new versions. Though, Composer you can keep as it doesn't directly talk to the JSS. However, Composer 8.6 squashed that re-naming bug so you'll probably want it.
  • August 8, 2012
Thanks for the response! So if I upgrade the Casper Suite to 8.6 will the upgrade preserve all of my preferences and packages created with the older version?
  • August 8, 2012
Yes it will. Though obviously, test test test.
  • August 9, 2012
Will I have to update Casper Imaging as well for it to work with the JSS 8.6 server or will Casper Imaging 8.52 still work?
chris_kemp
Forum|alt.badge.img+20
  • August 9, 2012
You should update Casper Imaging as well.
