JSS Version 9.9 and Lost mode
  • March 23, 2016
  • 31 replies
  • 199 views
Show first post
  • July 6, 2016
Yep, it works on one ipad but not the iPad that is in lost mode. I've set my iPad into lost mode, turned off wifi, restarted the device and plugged in the lan cable and it still got internet connection but this other device doesn't. Same iPad model.
  • July 28, 2016
While testing the "Lost Mode" feature, I enabled it on an iPad that was enrolled using DEP. Then, pretending the iPad was stolen, I wiped it. Of course, when the iPad was restored I was able to enroll it again using DEP. But the "Lost Mode" feature was no longer functioning on the iPad. On a stolen iPad, I would want the iPad to still be unusable by being locked. Am I missing something?
  • July 28, 2016
It is up to the MDM vendor to implement in that way. Currently JAMF doesn't. I'm not sure if any of the other major MDM vendors do either. Lost Mode is an MDM command sent to the device. After re-enrollment (after say a DFU reset) the MDM would need to say "oh this device was in Lost Mode, put it back in Lost Mode, send another Lost Mode MDM command".
I don't think there is an FR on this. I was just thinking about this workflow yesterday and was thinking about making an FR.
cdenesha
  • July 29, 2016
We just set an Extension Attribute and based on that being Yes lock it down if and every time it is enrolled by DEP. If the Smart Group emails you then you can send another Lost Command and try to locate.. Or don't lock it down but get notified by email, because they think they've gotten away with it, and then get the location.
  • April 16, 2018
@tobiaslinder Good afternoon, where exactly is the GPS information accessible? I put an iPad into Lost Mode today and I cannot seem to find that information.
Thank you.
tobiaslinder
  • April 17, 2018
@skinford it’s under Security
