kernel extension not set
  • May 10, 2019
  • 4 replies
  • 24 views
Forum|alt.badge.img+20
i run the following command to get the TeamIdentifier to create the config profile for kernel extension, but then the teamIdentifier for this particular application comes up as 'not set'
codesign -dv --verbose=4 /Applications/YourApp.app
the application is Cisco AnyConnect Secure Mobility Client.app
does this mean i can't create the config profile to approve kernel extension?
so when this application get's installed the user will get the popup and will have to 'allow' it ?
Best answer by tcandela
I have the Cisco AnyConnect 4.8.00175 version ( compatible with 10.13, 10.14, 10.15) and now this one has the Team Identifier.
  • May 14, 2019
if the application has the TeamIdentifier NOT SET does that mean a config profile can't be made for approve kernel extension?
  • May 14, 2019
So, the only time I've seen Not set for a TeamIdentifier is with some built in Apple apps, like Safari and iTunes. Most other 3rd party applications should have one.
I don't have access to AnyConnect anymore, so I can't really check, but taking a quick glance at this page, I see a TeamID listed for Cisco AnyConnect (pre 4.5 version) of DE8Y96K9QP on line 80 as I write this.
That being said, is it perhaps the TCC access info you're looking for here?
  • May 14, 2019
@mm2270 the version i'm test installing is 4.6 and i see NOT SET
i currently install 4.4 and i also get NOT SET
I don't see anything at all nearly related to DE8Y96K9QP
this is the command i'm using in terminal to get me the info. i've attached a picture of the results from the command
  • October 19, 2019
