how are the users changing the password? if you change it through the system preferences dialog in accounts, it will manage it for you. if however you have to change the password through some webpage, then you get to have the users manage it themselves AFAIK.
Todd Ness
Technology Consultant/Non-Windows Services
Americas Regional Delivery Engineering
HP Enterprise Services
This is what we see too. Most of our users use outlook web access to change password. We tell them to click "new keychain" when logging in and no real issues with that.
We use Keychain Minder (http://bit.ly/pN5bOU) as a login item for our users.
On Wed, Jul 20, 2011 at 2:12 PM, wintermute <wintermute at akapost.com> wrote:
It works,for the most part, and then we educated the users on how to change
their Keychain password if necessary.
Steve Wood
Director of IT
swood at integer.com
T 214.758.6813 | F 214.758.6901 | C 940.312.2475
If you change at the login window the users will be asked to update their keychain password. But I think the wording is confusing.
As such, I still deploy AFP548's Keychain Minder & run it at login.
Gives the users another prompt & one that's better worded.
Regards,
Ben.
Thanks so much to everyone that replied. It's impressive how quick and kind
you all are.
I don't think I provided enough detail in my initial message. Let me give
an example of one of the problems I'm running into. When the password in AD
gets reset, so does the email password. For Entourage users, this means
they get prompted again for a keychain password as the keychain in login
still contains the old password. I'd like to synchronize keychain items
like the one for Entourage with the network password without the user having
do re-enter anything.
--missing content--
doing it through JAMF.
If anyone has anything else to add it is much appreciated.
Regards,
JL
for that, use Kerberos instead of a saved password in keychain. if your AD environment is working properly, clients should get tickets. configure entourage/outlook to use Kerberos, and it should work. "should."
sent that from the grocery storeā¦
apart from using kerberos, you're looking at manual changes to keychain entries.
if you know the users' previous and current passwords, you can programmatically change them with the /usr/bin/security command. it's not likely you have those details, though.
aside from scripting this type of change yourself, jamf/casper offers nothing special to deal with the issue.
One of the projects I'm working on is intended to handle all of these situations, without requiring a working Kerberos setup. It will take me a long time though. Here are a couple screenshots I made:
I'm operating on the principle that Single Sign-On can be successfully set up with relative ease if the application doing the setup has access to the user's current password. At the moment, I'm just researching this, and trying to get Python access to the Keychain (grrrrrr....). I'll let you know when I have something workable, but keep in mind you will need to customize it almost completely for your environment.
Still not sure whether I want to keep the Skip button in there or not...
--missing content--
Regards,
JL
Thank you very much, Nate. This information is helpful and appreciated.
Thanks again to everyone that replied.
Regards,
JL
