Local Admin Account Creation (Without Casper) using Script.
  • December 8, 2012
  • 9 replies
  • 81 views
I have created a local admin account using below given script and its working fine for me.
#Creating a new user.
dscl . -create /Users/test6
#Setting users default shell.
dscl . -create /Users/test6 UserShell /bin/bash
#Setting up users Full Name
dscl . -create /Users/test6 RealName TEST6
dscl . -create /Users/test6 UniqueID 512
dscl . -create /Users/test6 PrimaryGroupID 20
dscl . -create /Users/test6 NFSHomeDirectory /Users/test5
dscl . -passwd /Users/test6 123456
dscl . -append /Groups/admin GroupMembership test6
I am not enough knowledgeable in scripting part.
I am looking for solution code for searching next available UniqueID from the system when i run the script.any idea will appreciated.
Best answer by rockpapergoat
you could try something like this:
dscl . -list /users UniqueID| sort -n -k 2 | awk '{ field = $NF }; END{ print field }' | xargs -I{} expr {} + 1
  • December 8, 2012
  • December 8, 2012
@ rockpapergoat, Its working.
Regards,
SonuW
  • December 8, 2012
Nate, your solution doesn't seem to account for any cached AD accounts, at least in my case. When I run that I get a UID returned in the AD range, i.e 10 digits long. It should probably only be looking at UIDs between 500 and 1000. Might want account for that, since I don't know if it would be a good idea to create a local admin account with a UID in a directory service range.
I was able to modify it like this and it worked in my case:
dscl . -list /Users UniqueID | sort -n -k 2 | awk '$2 < 1000 { field = $NF }; END{ print field }' | xargs -I{} expr {} + 1
  • December 9, 2012
mike, that sounds reasonable enough to me.
  • October 31, 2013
This is a little different then what I am looking for but maybe you guys have a suggestion.
I would like to create a script that would check to ensure that our local hidden "casper" admin account is present. And if it is not...to add it. Any suggestions?
  • October 31, 2013
check the box that says ensure account exists in the settings of casper would be the most appropriate thing to do i would think.
otherwise use the dscl command to search for your hidden admin account if its not in the list create it.
or being @TheMacGuys are you wanting one of the unix guys to write the script for you :)
  • October 31, 2013
Nice.....
Where to look for that little check box would be helpful?
I have a little scripting experience, when I have time I am usually pull off some decent scripts but in my job roll, doing everything, I just don't have time so often I do look for scripting help. As awesome as it is I just can't add one more expertise into my schedule so I have to count on some outside help.....
  • October 31, 2013
As @nessts][/url][/url][/url][/url mentioned, use dscl to look for your hidden account. I'm assuming its always named the same thing?
dscl . list /Users | grep ^hiddenadmin$
or if you want to limit the search to only sub 501 UID accounts:
dscl . list /Users UniqueID | awk '$2 < 501 {print $1}' | grep ^hiddenadmin$
Use a test situation to see if it returns a result, and if it doesn't then go about creating it in the rest of the script.
Keep in mind though that you'd be assigning a password for the account in plain text within the script, so just something to note from a security standpoint.
Edit: to get around the above situation, it might actually be better to have the script call a policy that creates the account with a custom trigger, that way the jamf binary is taking care of creating the account and not something coded directly in the script itself.
  • November 1, 2013
Very cool guys, thank you very much for the feed back. I am out now for a week..out to MacTech in CA. But I will see if I can muster some time to work on this when I get back.
