I'm starting to see an issue with our Mac's (bond to AD) will lose their connection to AD. Here are the symptoms that I notice when I start having odd issues:
My wireless will not connect. (We use Computer Authentication, which requires your Mac to be bond to our AD) My Domain admin account will no longer be able to "unlock" preferences or do any admin task.
If I try to use dscl to browse AD, I'm able to do a "ls" at the top level and see "/Active Directory" and then cd (change directory) to /Active Directory. Next I do "ls" again and see our domain LPCDOMAIN1, but I can't change directory to it. It will give me an error message. (sorry I don't have that wrote down)
Troubleshooting step:
When I check the "Login Options" under Uesr&Groups, it show that I'm joined to AD and will list my domain name and the green light.
I'm able to find my computer name in AD, when searching with "MS Active Directory Users and Computers" tool.
My Search Path will show /Local/Default and /Active Directory
I'm able to ping my DC by IP and name.
It acts like the mac is bond to AD, but can't talk to it.
Work around:
Unbind from AD
Rebind to AD
Reboot
I'm wondering if anyone has seen something like this. This has only happened on a few Macs and all of them were running 10.10.2.
Most of our Mac's are still on 10.9.5 and never experienced this issue.
Yes, it's a common issue if a computer stops communicating with the domain controller (particularly on laptops where the user may rely on wireless for the most part). It's on my to do list to have an extension attribute that checks the status of the computer's binding and if it can't communicate then attempt to rebind. Perhaps someone may have something like that already and would be willing to share, but you'd definitely have to tweak it to your environment.
Curious, but is this happening on Macs you use regularly and are connected to your internal network? They aren't Macs that are sitting in a drawer or in a storage shelf somewhere for awhile?
One of the Mac's that had the issue was my MacBook Pro that I use everyday. This is what stumped me. I can see if it was off line for awhile.
Two things that are what we check first with this:
1) Clock. Make sure it's not >5 mins off from AD.
2) Check Active Roles to see of the Mac has moved to disabled or other group that would kill functionality.
98% of the issues like that are fixed with those two items.
We run a tool that verifies the binding to AD every time the computer boots as well, if it thinks it is not bound it re-binds to AD. Sometimes the computer password does not get updated in AD, and looses authentication.
dsconfigad -passinterval? Other patterns (e.g. number of days before connectivity problem)?
As was mentioned time skew and disabled/tombstoned computer accounts perhaps?
802.1x with Yosemite has not been fruitful for us.
We have an extension attribute for AD checks that does two things: runs an "id" on a test user account we have (to see if the LDAP query succeeds) and also checks the System keychain for the Active Directory password entry for the computer account.
One of the bugs we see relatively commonly when there is an AD bind issue is that the AD password disappears from the System keychain for some reason. This also happens sometimes during the bind, and the password entry is simply not added at all.
Something like this:
# AD Bind Check Extension Attribute
adName=`dsconfigad -show | grep "Computer Account" | awk '{print toupper}' | awk '{print $4}' | sed 's/$$//'`
if [ ! "$adName" ]; then
    echo "<result>Not Bound</result>"
    result1="Bound as $adName"
ldapTest=`id TESTACCOUNTNAME | grep UIDOFTESTACCOUNT`
if [ ! "$ldapTest" ]; then
    result2="LDAP Query Failed"
    result2="LDAP Query OK"
keychainTest=`security find-generic-password -l "/Active Directory/YOURDOMAINNAME" /Library/Keychains/System.keychain`
if [ ! "$keychainTest" ]; then
        result3="AD Password Missing"
        result3="AD Password OK"
echo "<result>$result1 - $result2 - $result3</result>"
We have a similar EA that does an Active Directory join verification. It also looks for the AD system keychain entry and does a look up against its own Computer record in AD.
Thanks for all the information. I never thought about checking the keychain for the AD password. I will make a note to check this, the next time the problem comes up.
I did test the "id" command against my domain account and that did work. Weird...
it is not a password stored in keychain, its part of the AD record, its not a real password at all and you cannot check for it. You have to know if the computer password needs to change weekly and use the passinterval to set your binding up properly if it needs to change more often than the default of 15 days I think. Also some AD environments do not require it to change, and work worse if you do have it set to change.
And like has been noted sometimes the AD plugin just stops talking and you need to rebind. so coming up with a tool like above is helpful to resolve those situations.
The AD password for the computer is most certainly stored in the System keychain, as an application password. Computers have passwords just like users do.
You can reveal that password in Keychain Access and use it to get a kerberos ticket for your computer's AD account if you wanted to.
@jleomcdo FWIW we set "passinterval" to 0 so our Mac clients never update/change their password.
@bentoms Is there a requirement to set the passinterval before the computer is bound to AD or can it be done after it's bound.
I currently use the JSS built-in directory binding with Casper Imaging. It's my observation with 9.65 that the binding can take place before any "install on boot drive after imaging" packages or "at reboot" scripts take place. Would I need to go back to scripting the bind process with a custom trigger to control the order: set the passinterval and then bind?
@jhalvorson change it post binding, add a script to the build & have that run "AFTER" & "AT REBOOT" that should then run "AFTER" the binding.
@bentoms I located the Apple KB that gave me the impression the passinterval should be set prior to the time of binding. Changing the password expiration time for an Active Directory client It's possible that Apple wrote the directions this way to cover both a broken bound device, the solution, and rebinding all in one step.
I am on your side and based on experience, the value is honored if it is set after binding. I could test by setting it to 1 day and leaving a device in a drawer over the weekend.
We have around 70 macs in our environment and in the past 3 or 4 months have seen this happen 3 or 4 times, all on different machines. The strange part is that from almost every aspect it looks as though the mac and the server are still communicating and connected properly. In Users & Groups preference pane the domain is shown with a green light, the Active Directory entry is still shown in the keychain, running dsconfigad shows proper name and domain, the server side listing shows a recent last logon entry, are able to ping the domain controller from the affected machine, but when running "id ACCOUNT" command with a known working account it comes back no such user, and if we try to unbind and rebind it gives the "Unable to access domain controller" and the option to force unbind. Doing a force unbind and deleting the computer entry from the server and rebinding fixes the problem, but we would like to find a way to possibly prevent the issue. If not we will attempt to set up an extension attribute to do a rebind if this happens. Any suggestions would be greatly appreciated
Most of the indicators (dsconfigad -show, system preferences etc) aren't showing the actual state of the connection unfortunately.
If you haven't set it already, I would try setting the computer password interval to 0 (dsconfigad -passinterval 0) and running the free centrify AD check tool to see if it highlights any issues.
@davidacland do you have a link to the AD Check tool. I can't seem to find in on the Centrify website or on google anywhere
@jellingson You can get it as part of Centrify Express here: http://www.centrify.com/express/identity-service/mac-download/
Running the AD Check tool returns a pass on all tests
We see the same thing here. I use a script that checks to see if the keychain exists, and that it can use dscl to view the computer object. If any of those returns false, it force unbinds, then rebinds to AD.
@bbot
Can you post that script? Please?
We use script parameters so that passwords aren't in plain text. Also I've found that force unbinding twice seemed to have better results. When we did one unbind, the script would get stuck and exit out.
# HARDCODED VALUES ARE SET HERE
Pass=""
# CHECK TO SEE IF VALUES WERE PASSED FOR $4, AND IF SO, ASSIGN THEM
if [ "$4" != "" ] && [ "$Pass" == "" ]; then
Pass=$4
# Check to make sure Pass variable was passed down from Casper
if [ "$Pass" == "" ]; then
echo "Error: The parameter 'Pass' is blank. Please specify a value."
exit 1
##Check if Mac is on the network
if ping -c 2 -o domaincontroller.company.com; then
    if [[ $(dsconfigad -show | awk '/Active Directory Domain/{ print $NF }') == "domaincontroller.company.com" ]]; then
        ADCompName=$(dsconfigad -show | awk '/Computer Account/{ print $NF }')
        ## Mac has correct dsconfigad info
            security find-generic-password -l "/Active Directory/Domain" | grep "Active Directory"
            if [ "$?" == "0" ]; then
                ## AD keychain entry exists
                dscl "/Active Directory/Domain/All Domains" read /Computers/"$ADCompName" | grep -i "$ADCompName"
                    ## Found AD entry. Binding is good
                    res="Mac is already bound"
                    res="Not bound"
                res="Not bound"
        res="Not bound"
        res="Not bound"
    ## Mac is not on the network
echo "<result>$res</result>"
# reset the time from the domain, then force unbind if bound
if [[ $res == "Not bound" ]]; then
    /usr/sbin/systemsetup -setusingnetworktime off
    /usr/sbin/systemsetup -setnetworktimeserver "domaincontroller.company.com"
    /usr/sbin/systemsetup -setusingnetworktime on
    sleep 10
    /usr/sbin/dsconfigad -remove -force -username macimaging -password $4
    sleep 10
    echo "Unbinding"
    killall opendirectoryd
    sleep 5
## Testing has shown that unbinding twice may be necessary.
    /usr/sbin/dsconfigad -remove -force -username macimaging -password $4 &> /dev/null
    sleep 10
    echo "Unbinding twice just incase"
## Begin rebinding process
    #Basic variables
    computerid=`scutil --get LocalHostName`
    domain=domaincontroller.company.com
    udn=account
    ou="CN=Computers,DC=DOMAIN,DC=DOMAIN,DC=us"
    #Advanced variables
    alldomains="disable"
    localhome="enable"
    protocol="smb"
    mobile="enable"
    mobileconfirm="disable"
    user_shell="/bin/bash"
    admingroups="CorpHelpdesk"
    namespace="domain"
    packetsign="allow"
    packetencrypt="allow"
    useuncpath="disable"
    passinterval="90"
    # Bind to AD
    /usr/sbin/dsconfigad -add $domain -alldomains $alldomains -username $udn -password $4 -computer $computerid -ou "$ou" -force -packetencrypt $packetencrypt
    sleep 1
    echo "Rebinding to AD and setting advanced options"
    #set advanced options
    /usr/sbin/dsconfigad -localhome $localhome
    sleep 1
    /usr/sbin/dsconfigad -groups "$admingroups"
    sleep 1
    /usr/sbin/dsconfigad -mobile $mobile
    sleep 1
    /usr/sbin/dsconfigad -mobileconfirm $mobileconfirm
    sleep 1
    /usr/sbin/dsconfigad -alldomains $alldomains
    sleep 1
    /usr/sbin/dsconfigad -useuncpath "$useuncpath"
    sleep 1
    /usr/sbin/dsconfigad -protocol $protocol
    sleep 1
    /usr/sbin/dsconfigad -shell $user_shell
    sleep 1
    /usr/sbin/dsconfigad -passinterval $passinterval
    sleep 1
    #dsconfigad adds "All Domains"
    # Set the search paths to "custom"
    dscl /Search -create / SearchPolicy CSPSearchPath
    dscl /Search/Contacts -create / SearchPolicy CSPSearchPath
    sleep 1
    # Add the "XXXXX.us" search paths
    dscl /Search -append / CSPSearchPath "/Active Directory/CORP/domaincontroller.company.com"
    dscl /Search/Contacts -append / CSPSearchPath "/Active Directory/CORP/domaincontroller.company.com"
    sleep 1
    # Delete the "All Domains" search paths
    dscl /Search -delete / CSPSearchPath "/Active Directory/CORP/All Domains"
    dscl /Search/Contacts -delete / CSPSearchPath "/Active Directory/CORP/All Domains"
    sleep 1
    # Restart opendirectoryd
    sleep 5
    echo "Mac is already bound. Exiting."
@ooshnoo
@bbot
Thanks! Much appreciated!
I'll chine in alongside @bbot
@ooshnoo
We use an Extension Attribute and we call it "Check Active Directory Health". It just checks to see if AD is reachable. If not, the Mac falls into a Smart Group.
The Smart Group has a policy scoped to it that updates the Mac's time to match NTP, then unbinds and rejoins it to AD.
Here's the EA:
domain=""
user="insert any AD user here"
# Can we query a UPN?
domainAns=`dscl /Active Directory/${domain}/All Domains -read /Users/${user} dsAttrTypeNative:userPrincipalName`
if [[ $domainAns =~ "is not valid" ]]; then
    result="Invalid"
        result="Valid"
