Mac PreStage Being Bypassed
  • May 19, 2016
  • 16 views
Hi everyone,
We are having an issue where the OSX Setup assistant is being bypassed once done imaging with Casper. We have tried with blank OSX images made from capturing a computer via Composer, Disk Utility and AutoDMG. None of those are working properly. We had this set up and working up until we updated to 9.9. If I remove the .AppleSetupDone file I can go back to the setup and force the PreStage, but if I include it in the imaging process, it still bypasses it and goes to the Login Window. Any thoughts would be great!
Best answer by rhoward
@thoule I figured out why I had the issue. My remove .AppleSetupDone script wasn't set to run on reboot. Thanks!
Forum|alt.badge.img+15
  • May 19, 2016
In Casper Imaging, click Show Custom then click the Advanced Tab. At the bottom, check the box for 'Show OS X Setup Assistant'.
  • May 23, 2016
