HI, I know this is non JAMF question but...
Will it be possible to use Open GL quad buffered stereo (in windowed mode) on the new Mac Pro with the AMD D300-700 graphics cards?
What we want to do is connect the Mac Pro to a 120 Hz display and then use active shutter glasses for stereoscopic viewing. Since there is obviously no 3-pin VESA connector on the new Mac Pro, to which one would normally connect the infrared emitter for shutter glasses, I hope that the shutter glasses from Samsung, which connect via Bluetooth, might work.
In the previous Mac Pro models, it was possible to install an nVidia Quad card with 3-pin VESA connector and this worked well for the application we will need it for.
Many Thanks
Carmelo
