MacAir will not reboot after "jamf createAccount"
ran the following script on a macbook air... after doing so... SSH does not work.. and when you try to reboot, it stays at the Apple logo screen...
/usr/sbin/jamf createAccount -username CasperAdminAccount -realname CasperAdminAccount -password whatever -home /private/var -admin -hidden -secureSSH
Best answer by hkabikDMA
Not sure if this is the issue… but the -home path should be /private/var/username. It's possible that making the home folder the whole /private/var folder messed with some boot necessary files.
  • July 17, 2014
  • July 18, 2014
I think that was it... I changed the home folder path and my client seems to be happy now. Now i have to fix the test machine I broke.
I did a reinstall without formatting using the recovery part... which seems to be ok. But I wonder if there is an easier way...
Thank you so much for the tip!
