MacOS Monterey Beta and Jamf Agent
  • June 29, 2021
  • 5 replies
  • 54 views
Hey Folks - Has anyone installed the MacOS Monterey beta and got the following error regarding the Jamf client?
When you click on "Learn More..." you are taken to a site indicating that Python 2 isn't going to be supported much longer.
Cayde-6
Forum|alt.badge.img+22
  • June 30, 2021
Yep I’m sure jamf DEV guys are on it.
iJake
Forum|alt.badge.img+23
  • June 30, 2021
Please remember that any Apple Betas are technically under NDA and as such you should be careful what you post and where.
  • June 30, 2021
Yikes, that's a point I hadn't even considered @iJake , i usually considered this group to be sort of "hand in hand" with Apple but its really not. Do you think I should take this down?
Cayde-6
  • June 30, 2021
I personally don’t see any offending material, I’ve certainly seen the same screenshots in the slack MacAdmins channels but that’s my opinion anyway.
sfiguet
  • July 27, 2021
Hello. Is JamfPro Agent compatible with macOS Monterey fresh install ?
For me, with the beta 3, i have some profiles installed but not the jamf binary.
Our Jamfpro plateform is 10.30.3-t1624643096.
And you ?
