Hi all!
So we worked with Jamf Professional Services to learn about DEPNotify and how we could implement it. It's super cool, and easy to implement - however, we saw Hoppy Shaw's video where he talks about deploying it, and noticed he had several scrolling sections of 'main text' to display while the progress bar continued on. We'd like to do this, as we could streamline a bunch of clunky enrollment windows this way, but I'm a little confused as to where we could use the Maintext command... I've altered the script a bit so it doesn't reveal company-specific info. Any ideas?
# Version 2.0.1
# License information
# Copyright 2020 Jamf Professional Services
# Permission is hereby granted, free of charge, to any person obtaining a copy of this
# software and associated documentation files (the "Software"), to deal in the Software
# without restriction, including without limitation the rights to use, copy, modify, merge,
# publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons
# to whom the Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all copies or
# substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
# INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
# PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE
# FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR
# OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# General Information
# This script is designed to make implementation of DEPNotify very easy with limited
# scripting knowledge. The section below has variables that may be modified to customize
# the end user experience. DO NOT modify things in or below the CORE LOGIC area unless
# major testing and validation is performed.
# Build for X Corporation
# Created by Gio Martell
# Jamf PSE
# Modified for Use by D. McCullough
# Testing Mode
# Testing flag will enable the following things to change:
# Auto removal of BOM files to reduce errors
# Sleep commands instead of policies or other changes being called
# Quit Key set to command + control + x
TESTING_MODE=false # Set variable to true or false
# General Appearance
# Flag the app to open fullscreen or as a window
FULLSCREEN=true # Set variable to true or false
# Banner image can be 600px wide by 100px high. Images will be scaled to fit
# If this variable is left blank, the generic image will appear. If using custom Self
# Service branding, please see the Customized Self Service Branding area below
BANNER_IMAGE_PATH="/usr/local/mk/logo.png"
# Main heading that will be displayed under the image
# If this variable is left blank, the generic banner will appear
BANNER_TITLE="Welcome to X!"
# Paragraph text that will display under the main heading. For a new line, use
# If this variable is left blank, the generic message will appear. Leave single
# quotes below as double quotes will break the new lines.
MAIN_TEXT='Please wait while your computer is being configured and software is being installed. This process should take approximately 30 minutes, depending on your network connection speed.
  Thank you for your patience.'
# Initial Start Status text that shows as things are firing up
INITAL_START_STATUS="Initial configuration starting..."
# Text that will display in the progress bar
INSTALL_COMPLETE_TEXT="Configuration complete!"
# Complete messaging to the end user can ether be a button at the bottom of the
# app with a modification to the main window text or a dropdown alert box. Default
# value set to false and will use buttons instead of dropdown messages.
COMPLETE_METHOD_DROPDOWN_ALERT=false # Set variable to true or false
# Text that will display inside the alert once policies have finished
# Option for dropdown alert box
COMPLETE_ALERT_TEXT="Your Mac is now finished with initial setup and configuration. Press Quit to get started!"
# Options if not using dropdown alert box
COMPLETE_MAIN_TEXT='Your Mac is now finished with initial setup and configuration.'
COMPLETE_BUTTON_TEXT="Restart"
# Plist Configuration
# The menu.depnotify.plist contains more and more things that configure the DEPNotify app
# You may want to save the file for purposes like verifying EULA acceptance or validating
# other options.
# Plist Save Location
# This wrapper allows variables that are created later to be used but also allow for
# configuration of where the plist is stored
INFO_PLIST_WRAPPER (){
DEP_NOTIFY_USER_INPUT_PLIST="/Users/$CURRENT_USER/Library/Preferences/menu.nomad.DEPNotifyUserInput.plist"
# Status Text Alignment
# The status text under the progress bar can be configured to be left, right, or center
STATUS_TEXT_ALIGN="center"
# Help Button Configuration
# The help button was changed to a popup. Button will appear if title is populated.
HELP_BUBBLE_TITLE="Need Help?"
HELP_BUBBLE_BODY="This tool is designed to help with new employee onboarding. If you have issues, please contact X"
# Error Screen Text
# If testing mode is false and configuration files are present, this text will appear to
# the end user and asking them to contact IT. Limited window options here as the
# assumption is that they need to call IT. No continue or exit buttons will show for
# DEP Notify window and it will not show in fullscreen. IT staff will need to use Terminal
# or Activity Monitor to kill DEP Notify.
ERROR_BANNER_TITLE="Uh oh - something needs fixed!"
ERROR_MAIN_TEXT='We are sorry that you are experiencing this inconvenience with your new Mac. X.'
# Error status message that is displayed under the progress bar
ERROR_STATUS="Setup failed."
# Policy Variable to Modify
# The policy array must be formatted "Progress Bar text,customTrigger". These will be
# run in order as they appear below.
POLICY_ARRAY=(
"Installing x...,x"
"Installing x...,x"
"Installing x...,x"
"Installing y...,y"
# Caffeinate / No Sleep Configuration
# Flag script to keep the computer from sleeping. BE VERY CAREFUL WITH THIS FLAG!
# This flag could expose your data to risk by leaving an unlocked computer wide open.
# Only recommended if you are using fullscreen mode and have a logout taking place at
# the end of configuration (like for FileVault). Some folks may use this in workflows
# where IT staff are the primary people setting up the device. The device will be
# allowed to sleep again once the DEPNotify app is quit as caffeinate is looking
# at DEPNotify's process ID.
NO_SLEEP=true
# EULA Variables to Modify
# EULA configuration
EULA_ENABLED=false # Set variable to true or false
# EULA status bar text
EULA_STATUS="Waiting for completion of the EULA agreement."
# EULA button text on the main screen
EULA_BUTTON="Read and Agree to EULA"
# EULA Screen Title
EULA_MAIN_TITLE="Organization End User License Agreement"
# EULA Subtitle
EULA_SUBTITLE="Please agree to the following terms and conditions to start configuration of this Mac."
# Path to the EULA file you would like the user to read and agree to. It is
# best to package this up with Composer or another tool and deliver it to a
# shared area like /Users/Shared/
EULA_FILE_PATH="/Users/Shared/eula.txt"
# Registration Variables to Modify
# Registration window configuration
REGISTRATION_ENABLED=false # Set variable to true or false
# Registration window title
REGISTRATION_TITLE="Please enter the requested information.
# Registration status bar text
REGISTRATION_STATUS="Waiting on completion of computer registration"
# Registration window submit or finish button text
REGISTRATION_BUTTON="Register Your Mac"
# The text and pick list sections below will write the following lines out for
# end users. Use the variables below to configure what the sentence says
# Ex: Setting Computer Name to macBook0132
REGISTRATION_BEGIN_WORD="Setting"
REGISTRATION_MIDDLE_WORD="to"
# Registration window can have up to two text fields. Leaving the text display
# variable empty will hide the input box. Display text is to the side of the
# input and placeholder text is the gray text inside the input box.
# Registration window can have up to four dropdown / pick list inputs. Leaving
# the pick display variable empty will hide the dropdown / pick list.
# First Text Field
# Text Field Label
REG_TEXT_LABEL_1="McKesson Corporation  User name"
# Place Holder Text
REG_TEXT_LABEL_1_PLACEHOLDER="SMITHJ"
# Optional flag for making the field an optional input for end user
REG_TEXT_LABEL_1_OPTIONAL="false" # Set variable to true or false
# Help Bubble for Input. If title left blank, this will not appear
REG_TEXT_LABEL_1_HELP_TITLE="Domain ID"
REG_TEXT_LABEL_1_HELP_TEXT="This field requires the first four characters of the office location
 ex.SmithJ. This is important for inventory purposes."
# Logic below was put in this section rather than in core code as folks may
# want to change what the field does. This is a function that gets called
# when needed later on. BE VERY CAREFUL IN CHANGING THE FUNCTION!
REG_TEXT_LABEL_1_LOGIC (){
REG_TEXT_LABEL_1_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_TEXT_LABEL_1")
if [ "$REG_TEXT_LABEL_1_OPTIONAL" = true ] && [ "$REG_TEXT_LABEL_1_VALUE" = "" ]; then
echo "Status: $REG_TEXT_LABEL_1 was left empty. Skipping..." >> "$DEP_NOTIFY_LOG"
echo "$(date "+%a %h %d %H:%M:%S"): $REG_TEXT_LABEL_1 was set to optional and was left empty. Skipping..." >> "$DEP_NOTIFY_DEBUG"
sleep 5
echo "Status: $REGISTRATION_BEGIN_WORD $REG_TEXT_LABEL_1 $REGISTRATION_MIDDLE_WORD $REG_TEXT_LABEL_1_VALUE" >> "$DEP_NOTIFY_LOG"
if [ "$TESTING_MODE" = true ]; then
sleep 10
"$JAMF_BINARY" recon -endUsername "$REG_TEXT_LABEL_1_VALUE"
sleep 5
# Second Text Field
# Text Field Label
REG_TEXT_LABEL_2=""
# Place Holder Text
REG_TEXT_LABEL_2_PLACEHOLDER="Text"
REG_TEXT_LABEL_2_OPTIONAL="true" # Set variable to true or false
REG_TEXT_LABEL_2_HELP_TITLE="Asset Tag Field"
REG_TEXT_LABEL_2_HELP_TEXT="This field is used to give an updated asset tag to our asset management system. If you do not know your asset tag number, please skip this field."
REG_TEXT_LABEL_2_LOGIC (){
REG_TEXT_LABEL_2_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_TEXT_LABEL_2")
if [ "$REG_TEXT_LABEL_2_OPTIONAL" = true ] && [ "$REG_TEXT_LABEL_2_VALUE" = "" ]; then
echo "Status: $REG_TEXT_LABEL_2 was left empty. Skipping..." >> "$DEP_NOTIFY_LOG"
echo "$(date "+%a %h %d %H:%M:%S"): $REG_TEXT_LABEL_2 was set to optional and was left empty. Skipping..." >> "$DEP_NOTIFY_DEBUG"
sleep 5
echo "Status: $REGISTRATION_BEGIN_WORD $REG_TEXT_LABEL_2 $REGISTRATION_MIDDLE_WORD $REG_TEXT_LABEL_2_VALUE" >> "$DEP_NOTIFY_LOG"
sleep 10
"$JAMF_BINARY" recon -assetTag "$REG_TEXT_LABEL_2_VALUE"
# Popup 1
# Label for the popup
REG_POPUP_LABEL_1="Location"
# Array of options for the user to select
REG_POPUP_LABEL_1_OPTIONS=(
"United States"
"Canada"
"India"
"Great Britain"
"Sydney"
"Poland"
REG_POPUP_LABEL_1_HELP_TITLE="Select the Company"
REG_POPUP_LABEL_1_HELP_TEXT="Please choose the appropriate Company. This is important for Binding to AD."
REG_POPUP_LABEL_1_LOGIC (){
REG_POPUP_LABEL_1_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_POPUP_LABEL_1")
echo "Status: $REGISTRATION_BEGIN_WORD $REG_POPUP_LABEL_1 $REGISTRATION_MIDDLE_WORD $REG_POPUP_LABEL_1_VALUE" >> "$DEP_NOTIFY_LOG"
sleep 10
# Popup 2
REG_POPUP_LABEL_2=""
REG_POPUP_LABEL_2_OPTIONS=(
"Customer Onboarding"
"Professional Services"
"Sales Engineering"
REG_POPUP_LABEL_2_HELP_TITLE="Department Dropdown Field"
REG_POPUP_LABEL_2_HELP_TEXT="Please choose the appropriate department for where you normally work. This is important for inventory purposes."
REG_POPUP_LABEL_2_LOGIC (){
REG_POPUP_LABEL_2_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_POPUP_LABEL_2")
echo "Status: $REGISTRATION_BEGIN_WORD $REG_POPUP_LABEL_2 $REGISTRATION_MIDDLE_WORD $REG_POPUP_LABEL_2_VALUE" >> "$DEP_NOTIFY_LOG"
sleep 10
"$JAMF_BINARY" recon -department "$REG_POPUP_LABEL_2_VALUE"
# Popup 3 - Code is here but currently unused
REG_POPUP_LABEL_3=""
REG_POPUP_LABEL_3_OPTIONS=(
"Option 1"
"Option 2"
"Option 3"
REG_POPUP_LABEL_3_HELP_TITLE="Dropdown 3 Field"
REG_POPUP_LABEL_3_HELP_TEXT="This dropdown is currently not in use. All code is here ready for you to use. It can also be hidden by removing the contents of the REG_POPUP_LABEL_3 variable."
REG_POPUP_LABEL_3_LOGIC (){
REG_POPUP_LABEL_3_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_POPUP_LABEL_3")
echo "Status: $REGISTRATION_BEGIN_WORD $REG_POPUP_LABEL_3 $REGISTRATION_MIDDLE_WORD $REG_POPUP_LABEL_3_VALUE" >> "$DEP_NOTIFY_LOG"
sleep 10
sleep 10
# Popup 4 - Code is here but currently unused
REG_POPUP_LABEL_4=""
REG_POPUP_LABEL_4_OPTIONS=(
"Option 1"
"Option 2"
"Option 3"
REG_POPUP_LABEL_4_HELP_TITLE="Dropdown 4 Field"
REG_POPUP_LABEL_4_HELP_TEXT="This dropdown is currently not in use. All code is here ready for you to use. It can also be hidden by removing the contents of the REG_POPUP_LABEL_4 variable."
REG_POPUP_LABEL_4_LOGIC (){
REG_POPUP_LABEL_4_VALUE=$(defaults read "$DEP_NOTIFY_USER_INPUT_PLIST" "$REG_POPUP_LABEL_4")
echo "Status: $REGISTRATION_BEGIN_WORD $REG_POPUP_LABEL_4 $REGISTRATION_MIDDLE_WORD $REG_POPUP_LABEL_4_VALUE" >> "$DEP_NOTIFY_LOG"
sleep 10
sleep 10
# Core Script Logic - Don't Change Without Major Testing
#Check to see if DEPNotify is installed.  If not, install it...
if [ -f "/usr/local/mk/DEPNotify.app/Contents/MacOS/DEPNotify" ]
then
echo "DEPNotify is installed, will continue..."
echo "Does not have DEPNotify, will install..."
/usr/local/bin/jamf policy -event InstallDEPNotify
#Check if company icon is present.  If not, install it...
if [ -f "/usr/local/mk/logo.png" ]
then
echo "mk Icon is present, will continue..."
echo "mk Icon missing, will install..."
/usr/local/bin/jamf policy -event InstallLogo
# Variables for File Paths
JAMF_BINARY="/usr/local/bin/jamf"
FDE_SETUP_BINARY="/usr/bin/fdesetup"
DEP_NOTIFY_APP="/usr/local/mk/DEPNotify.app"
DEP_NOTIFY_LOG="/var/tmp/depnotify.log"
DEP_NOTIFY_DEBUG="/var/tmp/depnotifyDebug.log"
DEP_NOTIFY_DONE="/var/tmp/com.depnotify.provisioning.done"
# Pulling from Policy parameters to allow true/false flags to be set. More info
# can be found on https://urldefense.com/v3/__https://www.jamf.com/jamf-nation/articles/146/script-parameters__;!!KMayzP4JbQ!MUpG-0G-J6VXPp_z7vW5ayBeGXqxO3UTFfXdZhMSEvtgRlhXX1hht8GIFcmHKPrApgM_bQ$
# These will override what is specified in the script above.
# Testing Mode
if [ "$4" != "" ]; then TESTING_MODE="$4"; fi
# Fullscreen Mode
if [ "$5" != "" ]; then FULLSCREEN="$5"; fi
# No Sleep / Caffeinate Mode
if [ "$6" != "" ]; then NO_SLEEP="$6"; fi
# Complete method dropdown or main screen
if [ "$8" != "" ]; then COMPLETE_METHOD_DROPDOWN_ALERT="$8"; fi
# EULA Mode
if [ "$9" != "" ]; then EULA_ENABLED="$9"; fi
# Registration Mode
if [ "${10}" != "" ]; then REGISTRATION_ENABLED="${10}"; fi
# Standard Testing Mode Enhancements
# Removing old config file if present (Testing Mode Only)
if [ -f "$DEP_NOTIFY_LOG" ]; then rm "$DEP_NOTIFY_LOG"; fi
if [ -f "$DEP_NOTIFY_DONE" ]; then rm "$DEP_NOTIFY_DONE"; fi
if [ -f "$DEP_NOTIFY_DEBUG" ]; then rm "$DEP_NOTIFY_DEBUG"; fi
# Setting Quit Key set to command + control + x (Testing Mode Only)
echo "Command: QuitKey: x" >> "$DEP_NOTIFY_LOG"
# Validating true/false flags
if [ "$TESTING_MODE" != true ] && [ "$TESTING_MODE" != false ]; then
echo "$(date "+%a %h %d %H:%M:%S"): Testing configuration not set properly. Currently set to $TESTING_MODE. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
exit 1
if [ "$FULLSCREEN" != true ] && [ "$FULLSCREEN" != false ]; then
echo "$(date "+%a %h %d %H:%M:%S"): Fullscreen configuration not set properly. Currently set to $FULLSCREEN. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
exit 1
if [ "$NO_SLEEP" != true ] && [ "$NO_SLEEP" != false ]; then
echo "$(date "+%a %h %d %H:%M:%S"): Sleep configuration not set properly. Currently set to $NO_SLEEP. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
exit 1
if [ "$COMPLETE_METHOD_DROPDOWN_ALERT" != true ] && [ "$COMPLETE_METHOD_DROPDOWN_ALERT" != false ]; then
echo "$(date "+%a %h %d %H:%M:%S"): Completion alert method not set properly. Currently set to $COMPLETE_METHOD_DROPDOWN_ALERT. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
exit 1
if [ "$EULA_ENABLED" != true ] && [ "$EULA_ENABLED" != false ]; then
echo "$(date "+%a %h %d %H:%M:%S"): EULA configuration not set properly. Currently set to $EULA_ENABLED. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
exit 1
if [ "$REGISTRATION_ENABLED" != true ] && [ "$REGISTRATION_ENABLED" != false ]; then
echo "$(date "+%a %h %d %H:%M:%S"): Registration configuration not set properly. Currently set to $REGISTRATION_ENABLED. Please update to true or false." >> "$DEP_NOTIFY_DEBUG"
exit 1
# Run DEP Notify will run after Apple Setup Assistant
SETUP_ASSISTANT_PROCESS=$(pgrep -l "Setup Assistant")
until [ "$SETUP_ASSISTANT_PROCESS" = "" ]; do
echo "$(date "+%a %h %d %H:%M:%S"): Setup Assistant Still Running. PID $SETUP_ASSISTANT_PROCESS." >> "$DEP_NOTIFY_DEBUG"
sleep 1
done
# Checking to see if the Finder is running now before continuing. This can help
# in scenarios where an end user is not configuring the device.
FINDER_PROCESS=$(pgrep -l "Finder")
until [ "$FINDER_PROCESS" != "" ]; do
echo "$(date "+%a %h %d %H:%M:%S"): Finder process not found. Assuming device is at login screen." >> "$DEP_NOTIFY_DEBUG"
sleep 1
done
# After the Apple Setup completed. Now safe to grab the current user.
CURRENT_USER=$(/usr/bin/python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
echo "$(date "+%a %h %d %H:%M:%S"): Current user set to $CURRENT_USER." >> "$DEP_NOTIFY_DEBUG"
# Adding Check and Warning if Testing Mode is off and BOM files exist
if [[ ( -f "$DEP_NOTIFY_LOG" || -f "$DEP_NOTIFY_DONE" ) && "$TESTING_MODE" = false ]]; then
echo "$(date "+%a %h %d %H:%M:%S"): TESTING_MODE set to false but config files were found in /var/tmp. Letting user know and exiting." >> "$DEP_NOTIFY_DEBUG"
mv "$DEP_NOTIFY_LOG" "/var/tmp/depnotify_old.log"
echo "Command: MainTitle: $ERROR_BANNER_TITLE" >> "$DEP_NOTIFY_LOG"
echo "Command: MainText: $ERROR_MAIN_TEXT" >> "$DEP_NOTIFY_LOG"
echo "Status: $ERROR_STATUS" >> "$DEP_NOTIFY_LOG"
sudo -u "$CURRENT_USER" open -a "$DEP_NOTIFY_APP" --args -path "$DEP_NOTIFY_LOG"
sleep 5
exit 1
# Setting custom image if specified
if [ "$BANNER_IMAGE_PATH" != "" ]; then  echo "Command: Image: $BANNER_IMAGE_PATH" >> "$DEP_NOTIFY_LOG"; fi
# Setting custom title if specified
if [ "$BANNER_TITLE" != "" ]; then echo "Command: MainTitle: $BANNER_TITLE" >> "$DEP_NOTIFY_LOG"; fi
# Setting custom main text if specified
if [ "$MAIN_TEXT" != "" ]; then echo "Command: MainText: $MAIN_TEXT" >> "$DEP_NOTIFY_LOG"; fi
# General Plist Configuration
# Calling function to set the INFO_PLIST_PATH
INFO_PLIST_WRAPPER
# The plist information below
DEP_NOTIFY_CONFIG_PLIST="/Users/$CURRENT_USER/Library/Preferences/menu.nomad.DEPNotify.plist"
# If testing mode is on, this will remove some old configuration files
if [ "$TESTING_MODE" = true ] && [ -f "$DEP_NOTIFY_CONFIG_PLIST" ]; then rm "$DEP_NOTIFY_CONFIG_PLIST"; fi
if [ "$TESTING_MODE" = true ] && [ -f "$DEP_NOTIFY_USER_INPUT_PLIST" ]; then rm "$DEP_NOTIFY_USER_INPUT_PLIST"; fi
# Setting default path to the plist which stores all the user completed info
defaults write "$DEP_NOTIFY_CONFIG_PLIST" pathToPlistFile "$DEP_NOTIFY_USER_INPUT_PLIST"
# Setting status text alignment
defaults write "$DEP_NOTIFY_CONFIG_PLIST" statusTextAlignment "$STATUS_TEXT_ALIGN"
# Setting help button
if [ "$HELP_BUBBLE_TITLE" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" helpBubble -array-add "$HELP_BUBBLE_TITLE"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" helpBubble -array-add "$HELP_BUBBLE_BODY"
# EULA Configuration
if [ "$EULA_ENABLED" =  true ]; then
DEP_NOTIFY_EULA_DONE="/var/tmp/com.depnotify.agreement.done"
# If testing mode is on, this will remove EULA specific configuration files
if [ "$TESTING_MODE" = true ] && [ -f "$DEP_NOTIFY_EULA_DONE" ]; then rm "$DEP_NOTIFY_EULA_DONE"; fi
# Writing title, subtitle, and EULA txt location to plist
defaults write "$DEP_NOTIFY_CONFIG_PLIST" EULAMainTitle "$EULA_MAIN_TITLE"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" EULASubTitle "$EULA_SUBTITLE"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" pathToEULA "$EULA_FILE_PATH"
# Setting ownership of EULA file
chown "$CURRENT_USER:staff" "$EULA_FILE_PATH"
chmod 444 "$EULA_FILE_PATH"
# Registration Plist Configuration
if [ "$REGISTRATION_ENABLED" = true ]; then
DEP_NOTIFY_REGISTER_DONE="/var/tmp/com.depnotify.registration.done"
# If testing mode is on, this will remove registration specific configuration files
if [ "$TESTING_MODE" = true ] && [ -f "$DEP_NOTIFY_REGISTER_DONE" ]; then rm "$DEP_NOTIFY_REGISTER_DONE"; fi
# Main Window Text Configuration
defaults write "$DEP_NOTIFY_CONFIG_PLIST" registrationMainTitle "$REGISTRATION_TITLE"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" registrationButtonLabel "$REGISTRATION_BUTTON"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" registrationPicturePath "$BANNER_IMAGE_PATH"
# First Text Box Configuration
if [ "$REG_TEXT_LABEL_1" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField1Label "$REG_TEXT_LABEL_1"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField1Placeholder "$REG_TEXT_LABEL_1_PLACEHOLDER"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField1IsOptional "$REG_TEXT_LABEL_1_OPTIONAL"
# Code for showing the help box if configured
if [ "$REG_TEXT_LABEL_1_HELP_TITLE" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField1Bubble -array-add "$REG_TEXT_LABEL_1_HELP_TITLE"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField1Bubble -array-add "$REG_TEXT_LABEL_1_HELP_TEXT"
# Second Text Box Configuration
if [ "$REG_TEXT_LABEL_2" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField2Label "$REG_TEXT_LABEL_2"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField2Placeholder "$REG_TEXT_LABEL_2_PLACEHOLDER"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField2IsOptional "$REG_TEXT_LABEL_2_OPTIONAL"
if [ "$REG_TEXT_LABEL_2_HELP_TITLE" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField2Bubble -array-add "$REG_TEXT_LABEL_2_HELP_TITLE"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" textField2Bubble -array-add "$REG_TEXT_LABEL_2_HELP_TEXT"
# Popup 1
if [ "$REG_POPUP_LABEL_1" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton1Label "$REG_POPUP_LABEL_1"
if [ "$REG_POPUP_LABEL_1_HELP_TITLE" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu1Bubble -array-add "$REG_POPUP_LABEL_1_HELP_TITLE"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu1Bubble -array-add "$REG_POPUP_LABEL_1_HELP_TEXT"
# Code for adding the items from the array above into the plist
for REG_POPUP_LABEL_1_OPTION in "${REG_POPUP_LABEL_1_OPTIONS[@]}"; do
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton1Content -array-add "$REG_POPUP_LABEL_1_OPTION"
done
# Popup 2
if [ "$REG_POPUP_LABEL_2" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton2Label "$REG_POPUP_LABEL_2"
if [ "$REG_POPUP_LABEL_2_HELP_TITLE" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu2Bubble -array-add "$REG_POPUP_LABEL_2_HELP_TITLE"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu2Bubble -array-add "$REG_POPUP_LABEL_2_HELP_TEXT"
for REG_POPUP_LABEL_2_OPTION in "${REG_POPUP_LABEL_2_OPTIONS[@]}"; do
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton2Content -array-add "$REG_POPUP_LABEL_2_OPTION"
done
# Popup 3
if [ "$REG_POPUP_LABEL_3" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton3Label "$REG_POPUP_LABEL_3"
if [ "$REG_POPUP_LABEL_3_HELP_TITLE" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu3Bubble -array-add "$REG_POPUP_LABEL_3_HELP_TITLE"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu3Bubble -array-add "$REG_POPUP_LABEL_3_HELP_TEXT"
for REG_POPUP_LABEL_3_OPTION in "${REG_POPUP_LABEL_3_OPTIONS[@]}"; do
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton3Content -array-add "$REG_POPUP_LABEL_3_OPTION"
done
# Popup 4
if [ "$REG_POPUP_LABEL_4" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton4Label "$REG_POPUP_LABEL_4"
if [ "$REG_POPUP_LABEL_4_HELP_TITLE" != "" ]; then
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu4Bubble -array-add "$REG_POPUP_LABEL_4_HELP_TITLE"
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupMenu4Bubble -array-add "$REG_POPUP_LABEL_4_HELP_TEXT"
for REG_POPUP_LABEL_4_OPTION in "${REG_POPUP_LABEL_4_OPTIONS[@]}"; do
defaults write "$DEP_NOTIFY_CONFIG_PLIST" popupButton4Content -array-add "$REG_POPUP_LABEL_4_OPTION"
done
# Changing Ownership of the plist file
chown "$CURRENT_USER":staff "$DEP_NOTIFY_CONFIG_PLIST"
chmod 600 "$DEP_NOTIFY_CONFIG_PLIST"
# Opening the app after initial configuration
if [ "$FULLSCREEN" = true ]; then
sudo -u "$CURRENT_USER" open -a "$DEP_NOTIFY_APP" --args -path "$DEP_NOTIFY_LOG" -fullScreen
elif [ "$FULLSCREEN" = false ]; then
# Grabbing the DEP Notify Process ID for use later
DEP_NOTIFY_PROCESS=$(pgrep -l "DEPNotify" | cut -d " " -f1)
until [ "$DEP_NOTIFY_PROCESS" != "" ]; do
echo "$(date "+%a %h %d %H:%M:%S"): Waiting for DEPNotify to start to gather the process ID." >> "$DEP_NOTIFY_DEBUG"
sleep 1
done
# Using Caffeinate binary to keep the computer awake if enabled
if [ "$NO_SLEEP" = true ]; then
echo "$(date "+%a %h %d %H:%M:%S"): Caffeinating DEP Notify process. Process ID: $DEP_NOTIFY_PROCESS" >> "$DEP_NOTIFY_DEBUG"
caffeinate -disu -w "$DEP_NOTIFY_PROCESS"&
# Adding an alert prompt to let admins know that the script is in testing mode
echo "Command: Alert: DEP Notify is in TESTING_MODE. Script will not run Policies or other commands that make change to this computer."  >> "$DEP_NOTIFY_LOG"
# Adding nice text and a brief pause for prettiness
echo "Status: $INITAL_START_STATUS" >> "$DEP_NOTIFY_LOG"
sleep 5
# Setting the status bar
# Counter is for making the determinate look nice. Starts at one and adds
# more based on EULA, register, or other options.
ADDITIONAL_OPTIONS_COUNTER=1
if [ "$EULA_ENABLED" = true ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
if [ "$REGISTRATION_ENABLED" = true ]; then ((ADDITIONAL_OPTIONS_COUNTER++))
if [ "$REG_TEXT_LABEL_1" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
if [ "$REG_TEXT_LABEL_2" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
if [ "$REG_POPUP_LABEL_1" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
if [ "$REG_POPUP_LABEL_2" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
if [ "$REG_POPUP_LABEL_3" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
if [ "$REG_POPUP_LABEL_4" != "" ]; then ((ADDITIONAL_OPTIONS_COUNTER++)); fi
# Checking policy array and adding the count from the additional options above.
ARRAY_LENGTH="$((${#POLICY_ARRAY[@]}+ADDITIONAL_OPTIONS_COUNTER))"
echo "Command: Determinate: $ARRAY_LENGTH" >> "$DEP_NOTIFY_LOG"
# EULA Window Display Logic
echo "Status: $EULA_STATUS" >> "$DEP_NOTIFY_LOG"
echo "Command: ContinueButtonEULA: $EULA_BUTTON" >> "$DEP_NOTIFY_LOG"
while [ ! -f "$DEP_NOTIFY_EULA_DONE" ]; do
echo "$(date "+%a %h %d %H:%M:%S"): Waiting for user to accept EULA." >> "$DEP_NOTIFY_DEBUG"
sleep 1
done
# Registration Window Display Logic
echo "Status: $REGISTRATION_STATUS" >> "$DEP_NOTIFY_LOG"
echo "Command: ContinueButtonRegister: $REGISTRATION_BUTTON" >> "$DEP_NOTIFY_LOG"
while [ ! -f "$DEP_NOTIFY_REGISTER_DONE" ]; do
echo "$(date "+%a %h %d %H:%M:%S"): Waiting for user to complete registration." >> "$DEP_NOTIFY_DEBUG"
sleep 1
done
# Running Logic For Each Registration Box
if [ "$REG_TEXT_LABEL_1" != "" ]; then REG_TEXT_LABEL_1_LOGIC; fi
if [ "$REG_TEXT_LABEL_2" != "" ]; then REG_TEXT_LABEL_2_LOGIC; fi
if [ "$REG_POPUP_LABEL_1" != "" ]; then REG_POPUP_LABEL_1_LOGIC; fi
if [ "$REG_POPUP_LABEL_2" != "" ]; then REG_POPUP_LABEL_2_LOGIC; fi
if [ "$REG_POPUP_LABEL_3" != "" ]; then REG_POPUP_LABEL_3_LOGIC; fi
if [ "$REG_POPUP_LABEL_4" != "" ]; then REG_POPUP_LABEL_4_LOGIC; fi
# Loop to run policies
for POLICY in "${POLICY_ARRAY[@]}"; do
echo "Status: $(echo "$POLICY" | cut -d ',' -f1)" >> "$DEP_NOTIFY_LOG"
sleep 10
elif [ "$TESTING_MODE" = false ]; then
"$JAMF_BINARY" policy -event "$(echo "$POLICY" | cut -d ',' -f2)"
done
# Nice completion text
echo "Status: $INSTALL_COMPLETE_TEXT" >> "$DEP_NOTIFY_LOG"
if [ "$COMPLETE_METHOD_DROPDOWN_ALERT" = true ]; then
echo "Command: Quit: $COMPLETE_ALERT_TEXT" >> "$DEP_NOTIFY_LOG"
echo "Command: MainText: $COMPLETE_MAIN_TEXT" >> "$DEP_NOTIFY_LOG"
echo "Command: ContinueButtonRestart: $COMPLETE_BUTTON_TEXT" >> "$DEP_NOTIFY_LOG"
Be the first to reply!
