Management Commands Weirdness
  • August 10, 2017
  • 8 views
So I send a lock command to the computer and I get the following error back....
There was a problem communicating with a push server
The thing is if I login from a locked screen to the desktop AFTER a reboot the system then goes into reboot mode and locks. And the error goes away under management.
The computer will not lock if already logged in. It will not lock if you logout and log back in again.
Ideas? Thanks.
1 reply
  • August 11, 2017
And I just saw this. A new computer was added tonight and in the management tab this is what it said.
ProfileList There was a problem communicating with a push server
CertificateList There was a problem communicating with a push server
