Management Option missing - recent
  • September 12, 2017
  • 14 views
So I am getting MDM Compatibility - No The management option is missing. I've seen old discussion from last year about it was an issue that was with apple etc but this has only happened to 2 machines that we have from our 200+ estate.
Tried deleting from the JSS along with wiping on the machine with - jamf removeFramework
Has anyone been having issues recently and has some advice?
Thanks,
1 reply
Jamf response:
Looking though the logs and checking the error were seeing in there it seems theres already an MDM enabled user on the machine and were only allowed 1 concurrent mdm enabled user since mac OS 10.12. We will need to remove this and try again
can we run the following on the client:
sudo rm -rf /var/db/ConfigurationProfiles && sleep 30 && sudo /usr/local/jamf/bin/jamf manage && sudo /usr/local/jamf/bin/jamf recon && sleep 30 && sudo /usr/local/jamf/bin/jamf manage
Once thats run can we retry
/usr/local/jamf/bin/jamf mdm -userLevelMdm
THE ABOVE WORKED.
